Zintec sheet
Zintec sheet
Home Forums Materials Zintec sheet
  • #609878
    Mick Bailey
      @mickbailey28509
      Does anyone know of a fabricator or sheet metal place that has 1.5mm or 2mm Zintec sheet in the Stoke-on-Trent area? I used to have a plentiful source of free offcuts (some quite sizeable), but that's now finished.
      Mick Bailey
        @mickbailey28509
        #609889
        Dave Halford
          @davehalford22513
          Google throws this up Bodicar | Home
          #609904
          Mick Bailey
            @mickbailey28509
            That's outside my area, thanks. I'm looking for somewhere that's closer to home (ST13 postcode) so I can collect, and ideally someone who sells offcuts. The main stockist is nearby, but they only sell full sheets of 2500mmx1250mm in 1.5mm. I rang around and all I can find is 1mm cut to size from places that make ventilation and ducting.
            #610033
            Dave Halford
              @davehalford22513
              Looks like cars that last 15 years have killed of the old panel suppliers.
              #610049
              Mick Bailey
                @mickbailey28509
                1.5mm is thicker than generally used in car panels and is more likely to be used in general sheet metalwork.
                #610051
                Bazyle
                  @bazyle
                  Look for ventilation firms fitting out industrial buildings. There are probably a lot getting lots of orders for cooling upgrades and tend to use zinc sheet ductwork. Also look for industrial units being demolished which will be ripping out such ductwork.
                  Some washing machines have removable rear panels that are galvanised sheet.
                  #610059
                  John Hinkley
                    @johnhinkley26699
                    Mick,
                    metals4u.co.uk list 1.5mm zintec sheets 500 x 500mm, but at a price! I assume there is p&p on top. I didn't pursue my investigations after I picked myself up off the floor! Other, larger sizes are available.
                  Home Forums Materials Topics
