Posted by Ian S C on 10/04/2010 13:39:39:
Our light alloy and copper and alloy supplier here in Christchurch NZ has a good off cuts bin, also the will cut a bit of most things, no cost for small amounts. The chaps that run this firm started up when the large out fit that they worked for changed its policy toward the small buyer. Sounds like you need a few more of this type of supplyer in the UK. Ian S C
Ian different ball game the Zn12 is a specialist material and is only handled by a very small number of people as opposed to a non ferrous supplier.
The non ferrous supplier I use, ASC Metals at Lincoln will supply any quantity you need, no matter how big or small.
A while ago I needed a pulley 10″ diameter and 1″ wide, because I couldn’t afford 3 metres or 10″ alloy, or even lift it come to that I asked them for 1″
1″ was duly cut off presumably a long bar, and delivered to the door.
I also do a regular job out of 8mm thick alloy plate, these finish up at 100mm x 150mm so I order 10 pieces cut to 105 x 155 to allow for finishing.
Next day delivery and no messing having to manage a large plate and attempt to cut it.
John S.
Edited By John Stevenson on 10/04/2010 20:52:28
