I don't think there's anything else Cowells size which does Cowells quality jobs. I have the lathe and the mill. I also have a Proxxon FF230 mill, and a Unimat-3 in a shop on another continent and have fooled around with Sherline gear in a friend's shop.
The rigidity and the backgear of the Cowells lathe put it in another category of machine from anything else of similar size. The backgear in particular is a real game changer for boring jobs and screw cutting. Couldn't do anything like that on the Sherlines or Unimat.
Similar story with the mill. As a mill, it is absurdly superior to the little Proxxon. The Proxxon has a bigger, though less substantial table and vice, it has a bigger reach, and a drilling lever both of which are useful for drilling jobs. On the other hand, the Proxxon column is literally tubing, and it has an absurd tilting spindle which is a constant source of problems. Besides the difficulty of tramming the thing, the spindle housing is a chunk of aluminum with a weak clamping force; if you take a deep cut, it is guaranteed to knock itself over forcing you to retram. For mills of this size, this is a huge self-own. The Unimat-3 has a similar, smaller column mill attachment, but it didn't give me anywhere near as much trouble. I might just pin it at some point; it could certainly have come with that capability by default.
Cowells mill, not so useful as a drill press because of its configuration, but as it is made of cast iron and has an adjustable DC motor, you can do all kinds of milling jobs which are impossible on the Proxxon. For a little mill, you can take nice beefy cuts, and the collet system is absurdly superior to the one on the Proxxon. The Proxxon is cheaper and does adequate double duty as a drill press, but it isn't that much cheaper once you accessorize it enough to make it useful as a mill. It was definitely a case of buy cheap buy twice for me.
For my little workshop the Cowells tools give me capabilities I couldn't get with similar sized Chinese gear. Maybe something like a fully equipped Myford would allow me to do similar jobs in a similarly small amount of space, but nobody makes those any more, and it would probably cost more if I could find a good one. So, I'm pretty happy. Plus Colin is an incredibly nice person and it's great to be able to reach someone so close to the production line (I never asked; just assuming he is the production line). Try finding that with your Chinese tools.
I could probably squeeze another workbench/tool in the room at some point (I'm building a little hacksaw that doesn't count as it will live under the workbench most of the time). I could imagine finding uses for a larger lathe but for the types of things I'm interested in doing; little motors and clockworks, I feel pretty well equipped.
Edited By Morse Homology on 31/03/2022 13:50:37
