Posted by Alan Shepherd on 03/12/2022 22:32:20:
Thanks. I'm a little lost as i can't really see any obvious specification difference between the two. What spec sheets don't tell me is build quality and use ability, but while I can find plenty of feedback on the Sieg, the Amadeal lathe is more of an unknown. ![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
I went through the same uncertainty and eventually decided dithering was a waste of time. I got on with it, and ordered one from Warco who have a reasonable reputation. Later I discovered Arc Euro have the best reputation, but complaints about Amadeal seem rare.
The lathes are all made to a similar design, varying on things like motor power, brushless vs brushed, and accessories. They can be made by anyone with a suitable factory, not all wonderful, so beware buying cheap from unknown sources. I suspect factory rejects and returns become internet 'bargains' too. The UK suppliers are more careful about their sources, and in the event a dud gets to a customer, they'll sort it out, maybe with a refund.
Not sure they're still doing it, but Axminster offered an extended warranty – at a price. Bottom line, there's hassle if the purchase goes wrong, but nowhere near as painful as discovering you have to pay to return a faulty machine to a fulfilment centre in Germany! Or the supplier has disappeared, or only communicates in Mandarin!
In terms of capability, the machines share much the same virtues and vices. They mostly spin too fast to thread under power, which is fixed by making a hand-crank. The gear change banjo is fiddly compared with bigger machines. They're a bit too big and clunky to be good at fine work like clock-making, and a bit too small for larger general purpose work. On the plus side, they're light enough for a fit man to move on his own, are delightfully quiet, and provide all the main lathe functions. I learned a lot from mine!
All mini-lathes have much the same limitations: I'd rather have one with a brushless motor
