When bench testing I found the emergency stop option 19 in p50-55 had the same effect as option 0 (inertial stop ) in p12 or the same as when the power is cut and the motor just slowly spools down, not what you really want for an e-stop
Option 1 (deceleration stop) in p12 stops reasonably quickly and certainly quicker than my ml7 single phase lathe.
Option 2 (brake stop ) certainly stops quickly but would be quite mechanically unsympathetic if used constantly, though playing around with braking time/ voltage in p13/14 may help, I haven't tried that.
I have just acquired a Harrison m250 lathe and wanted to use the original controls as far as possible.
I have :
P50-x1 set to 3 NO momentary switch= start
P51-x2 set to 4 NO momentary switch = stop ( keeping the stop pressed in has no effect and pressing start will start the motor and you have to release the stop button and re-press to stop )
P52-x3 set to 9 wire reversing on the original rotary switch reverse
P52-x4 set to 15 section speed input 3 on the original rotary switch forward. This is for a slow forward set speed but could be programed in p29 for any frequency.
When the rotary switch is in the centre original off position, pressing start ,starts the lathe in forward, switching to original reverse, reverses and original forward gives slow forward without having to switch the lathe off. The stop p51- x2 works in all these positions and in the event of losing power, on restarting the vfd the lathe doesn't run until start is pressed.
Edited By iNf on 02/04/2022 23:18:41
