Yet another Arduino clock thread!
Home Forums Clocks and Scientific Instruments Yet another Arduino clock thread!
Viewing 3 posts - 101 through 103 (of 103 total)
  • #647176
    John Haine
      @johnhaine32865
      Posted by Joseph Noci 1 on 27/05/2023 07:29:07:
      Posted by S K on 26/05/2023 23:41:09:
      …And that zone is not adjustable but defined at manufacture. It is well defined and controlled and specified in the data sheets.
      So, yes, it depends on transistor thresholds – yes , all Schmitts do, but that applies to all comparator types anyway – not just Schmitt. The point being that a comparator becomes a defined Schmitt when we apply Hysteresis – we don.t need to fiddle with its transistor sizes…
      If I have your Schmitt concept wrong, if it is not a logic element, and not a comparator, could you provide a part number for the Schmitt device you have in mind?
      When I designed a handheld ultrasonic gadget many years back it used CMOS schmitt inverters for several functions, basically a single hex inverter. Several functions needed fairly precise thresholds between units and the only device I could find was the Motorola HCMOS version which was very repeatable. For normal "logic" interfacing the thresholds aren't very critical.
      John Haine
        @johnhaine32865
        First step towards fixing the light sensitivity problem. I've procured some IR filter material – this is ~3mm thick apparently black plastic which appears opaque to visible light but has no effect on the operation of the opto-interrupter where the peak emitter wavelength is 900nm. I've cut a small rectangle of this and tacked it to the sensor sides of the optos with a drop of superglue. Started another run yesterday afternoon, early indications are quite good but another cloudy morning here (1st June too…) so no sunshine. Next step if more is needed is to dissect the sensors as a couple of people have suggested, and mount the two halves further apart with collimator tunnels as well as a filter. If that fails then Plan C is modified electronics for the optos with AC coupling to reject ambient light signals. Watch this space.
        #647863
        John Haine
          @johnhaine32865
          Update. The filter material greatly reduces the effect though doesn't eliminate it entirely. Since the clock will eventually be mounted in a case with a glass door, I have decided to stick with the filter and the current sensors and use an infra-red absorbing film on the glass to filter out the wavelength of ambient light that the opto device uses. I have found a 3M product that looks ideal and should be easy to apply. So the filter on the sensor only passes the IR, and ambient IR will be greatly reduced by the film. Should work well enough I hope, we will see.
