Hi,
Yes it's daft question time again.
Does anyone know if they make penny washers OD 85m x ID 18mm x 10mm?
Now on the of chance that there is at least one of you brilliant people out there that's itching to say something like "you don't ned a penny washer you need a welder". What I need is two washers to make a leather maul one for each end.
So there are not being used as repair washers. But they will be under considerable force as they will need to be at least as wide as the top 75mm+. As wide as the base 50mm+. And have and internal diameter of just over ½''. And as they are going to be compressing 4'' of wet thick leather down to around 3''. Then they will need to be stronghence the guess of 10mm.
Now i doubt I can get any ready made. So can any one help me please with 4 XXXL washers please. Well 2 x 75mm and 2 x 50mm?
Thanks
Izzy
Edited By Izack Madd on 04/12/2014 16:53:48
