Worm for Myford Changewheels
Home Forums Beginners questions Worm for Myford Changewheels
  • #5134
    Baz
      @baz89810
      Baz
        @baz89810
        Gentlemen, I wish to cut a worm about 1 inch diameter to mesh with a Myford changewheel. Can somebody please tell me what pitch(TPI) the worm would need to be, and also what angle tool would I need? I am making a loco building stand for Sweet Pea and want the worm drive to rotate the loco. The price of a commercial worm and wheel is enough to make your eyes water. Thanks in anticipation.
        Baz
        #54041
        KWIL
          @kwil
          Myford gears are 20 DP.
          #54042
          Engine Builder
            @enginebuilder
            Bear in mind worm wheel teeth are cut at an angle to suit the worm. If you use a Myford change wheel the worm would need to be mounted at an ange and will not be  a perfect mesh. I have seen this is used in  homemade dividing attachments.
            David
            Edited By Engine Builder on 05/08/2010 12:59:29
            #54044
            chris stephens
              @chrisstephens63393
              Hi Baz,
              Do you have GHT’s book “The Model Engineers Workshop Manual”, if so check out his description of how it’s made.
              Details can also be found in Radford’s  “Improvements & Accessories for your Lathe”
              chriStephens
              #54045
              John Stevenson 1
                @johnstevenson1
                To answer the original question you need a worm with a pitch of 6.366 TPI, the tools needs to have a 29 degree included angle and the change wheels to cut this are 55 driving 35 with a 40 driver on the 35 to a 50 on the leadscrew.
                Do not disengage the half nuts but wind back every time.
                John S.
                #54048
                Baz
                  @baz89810
                  Thank you all for your replies, I have more than enough information now to tackle the job, hopefully it will be done sometime over the weekend.
                  Baz
