Posted by Hopper on 13/12/2022 21:07:59:
And also from Rocky Mountain motorcycling experience, long sleeved thermal underwear tops beat the heck out of mulitple jumpers etc for keeping warm and are way less bulky. The modern materials they use are amazingly warm but thin.
Based on Winter Mountaineering and Whitewater Kayaking, I would tend to agree that modern "Polartec" fleece thermals are the warmest thing I've found for a given thickness/restrictiveness, with other non-branded microfleeces coming in a reasonable second.
Full Pile fabrics as used in diver's and caver's "Wooly Bear" undersuits, or a Buffalo/Mardale/Montane Pile-Pertex Smock* is far and away the warmest option, but one of the smocks is about as bulky as a thick hoodie (although unlike a hoodie will keep you warm down to -15 as a single layer!)
The Helly-Hansen thermals with a sort of perforated texture and the stripey band down the arm (and other comparable ones) are quite good for their non-restrictiveness, but just aren't as warm as a piled fabric when you're stood still.
It's all about finding a fabric which will trap the maximal amount of the air next to your skin, which is why the pile times work so well.
All that touting fancy manufacturers of outdoor gear aside…
Years ago when i was a poor student primark did a set of blue microfleece thermals (i think long-johns, short and long sleeved t-shirt) for a couple of quid a piece, I tried some and found them plenty warm, but felt they were not at all cut for movement so bought fancier ones once when I could… but if you're just pottering about the workshop this isn't a problem.
They appear to be largely unchanged (other than by inflation)
* I keep debating the utility of making a pile lined smock out of something like cotton ventile or cordura which would have a better abrasion resistance than Pertex for use as a cold-weather working garment, but i'm keenly aware that the specific qualities of the Pertex fabric is a large part of why that system is warm without being sweaty, so you need to hit a goldilocks level of vapour/air permeability for the outer with minimal water absorbance.
My ideal would be to use Durably or Inherently Flame Retardant fabric for both inner and outer layers, but all the suitable outers would have similar compromises to above, and i'm pretty sure that a suitable pile fabric doesn't exist at present…
Everyone has to draw the line somewhere, and I'm pretty sure that weaving with nomex is over mine.
Edited By Jelly on 13/12/2022 23:47:32
