Workshop too cold and want to make something
Home Forums Suggested Online Resources Workshop too cold and want to make something
Viewing 25 posts - 1 through 25 (of 25 total)
  • #221570
    Ajohnw
      @ajohnw51620
      I wanted a lens for something and with postage costs just had to buy something else so went for this
      Which will need translating. The kit can be bought from their UK agents
      I will be interested to see if it does run backwards stood on a cold can of beer,
      Some astro people might find the site interesting. eg Want a 450mm fl guide scope, no idea if it would work out. Or fancy a 60 or 70mm finder but don't fancy the cost. As with finders these lenses will probably need a stop in the tube to restrict the field of view.
      I should add given how they have to pack some of the things they sell their postage costs are very reasonable.
      Ajohnw
        @ajohnw51620
        Stirling engine kit
        #221598
          Thanks for that John.
          Lots of fun bits for pocket money prices. A cheap way to achomat lenses, mirrors or even solar film for a 70mm scope!
          Ajohnw
            @ajohnw51620
            I wondered about the cardboard steam engine. Maybe next time. Steam's separated from the cardboard from a quick read.
            I have built the spectroscope kit as a trial for that particular type and to check some design maths out. I had the bright idea of using super glue. Fine if things are pressed down in exactly the right position. It would have been better to use something that could be unstuck and maybe leaving a bit of space for something stronger if needed later.
            Immediate thoughts was Super Pritt but which now seems to be called Power Pritt.
            They are the only source I know of for cheap achromats and the large ones were probably destined for finders.
              Posted by Ajohnw on 18/01/2016 16:15:34:
              John,
              If you don't know them already, have a look at SurplusShed
              Postal arrangements are very reasonable … After buying, they tell you what it would cost to ship, and you can cancel the order if you don't like the shipping cost.
              Ajohnw
                @ajohnw51620
                I've used Surplus Shed several times Michael. One trick which believe it or not can save money is to ask them to ship things separately. That sometimes results in all being below the import limit so no vat and better still no tax collection fee – that can vary a lot at times. Not sure why.
                sadI understand the limit is now £15. It was £18 and had been for a long time so really aught to be £30 plus.
                Last time I ordered off them was the optics for a Bath interferometer. Easily the cheapest for the items needed but also a small surplus Edmond's lens of Ebay.com. That can often also be a cheap source of optics,
                Why a Bath – final check on a telescope mirror when I get round to actually making it.
                laughI'd be more interested to know if any one else will be ordering the kit.
                Edited By Ajohnw on 18/01/2016 16:46:03
                #221612
                  Sorry I bothered mentioning SurplusShed then, John
                  Yes, the HMRC threshold is now £15 and:
                  • It's their choice of exchange rate [I think it's supposedly when it arrives in the UK]; which may or my not be what you got at the time of transaction.
                  • If you do go to £15.01 They apply the VAT to both the purchase price and the shipping !!
                  No, I won't be ordering the cardboard Stirling Engine kit.
                  Edited By Michael Gilligan on 18/01/2016 17:03:36
                  #221614
                    I've ordered a 50mm x 184mm achromat, which will be ideal for making a finder.
                    Will return again, probably for Baader solar film and I rather fancy making a 70mm reflector just for the fun of it.
                    Ajohnw
                      @ajohnw51620
                      That's what life should be about Neil most of the time when it's possible – fun.
                      If you make the reflector you could be the only person around with a quartz over coated mirror.
                      One thing to note on finders. I have had several and all of the ones that are any good and don't show any chromatic effect have a baffle well down the tube with a hole in it. I think it does 2 things. Reduced the field of view and also and probably a lot more importantly increases the F ratio number – the entire lens will  still contribute to the image. The magnification calc is still the same as it always is, I'd base that around what 50mm finders usually offer which I think is around 8 or 9x
                      laughI might be teaching my grandma to suck eggs but just in case. I'll measure one up if you come to grief if you like.
                      Edited By Ajohnw on 18/01/2016 19:24:26
                      #221642
                      Ajohnw
                        @ajohnw51620
                        surpriseI must get a life laugh. Just measured one. 50mm and focal length could well be 184mm. I measured it at 182. The lens cells screw on for focusing and has a locking ring. The baffle is approx 96mm back from the mid point of the lens and has 1" hole in it that might be 25mm. The hole edges should be very thin.
                        The baffle is very probably in the same place for right angle finders. It should be possible to scale the sizes for bigger lenses with longer focal lengths.
                        Somewhere to start anyway.
                        One other thing I can add. The size of the image the eyepiece views is 15 maybe 16mm dia.
                        Edited By Ajohnw on 18/01/2016 20:35:24
                        #221643
                        David Clark 13
                          @davidclark13
                          As well as the Vat on the parcel they include it on the postage and charge an £8 admin fee as well.
                          #221646
                          Ajohnw
                            @ajohnw51620
                            I've never been charged VAT on postage but have been charged more than £8 for admin. They should charge on postage so no idea why they don't always do that. Import duty is also possible on top of the vat, in fact I think it's added before vat when it has to be paid.
                            All stupid really. I asked a postman about it once. It seems that they get a lot in that has zero put in the customs value. However there is some indication that certain items are spotted when they go through customs and charged accordingly. Personally I don't mind the VAT but the £8 or more at times for sitting at my PC and paying the import duty and the £8 via a card electronically what ever it's value is really annoys me. It's all very treasure island Britain like many other sales related areas.
                            Then there are all of the parcels that come in from China that have $10 on them what ever is in it.
                              Posted by David Clark 1 on 18/01/2016 20:26:28:
                              Very true, David
                              That was my third bullet point, but I deleted it before posting … because Ajohnw appeared to 'know that already'.
                              P.S. … For anyone who hasn't yet suffered this form of robbery : here is HMRC's guide
                              Edited By Michael Gilligan on 18/01/2016 21:01:35
                              #221654
                              Ajohnw
                                @ajohnw51620
                                This thread has gone a long way from Astromediashop goodies which is a pity really – not that they sell that much astro stuff really.
                                However people might find Michael's link rather interesting if they can find details in it concerning importing antiques. What I have found the past concerning HMRC's doc's though is that they are seldom complete and specific details may be hard to find.
                                Antiques – seems to be a good example of what may apply to one sector of society but wont to another.
                                I imported a 150 year old pocket watch from the USA once to restore. No chance of finishing until I have a furnace to make a new dial.
                                  Posted by Ajohnw on 18/01/2016 22:29:38:
                                  question
                                  #221657
                                    John,
                                    I really don't know why you suddenly raised the matter of importing Antiques, but perhaps this will be of some interest.
                                    Ajohnw
                                      @ajohnw51620
                                      Posted by Michael Gilligan on 18/01/2016 23:00:18:
                                      John,
                                      I raised it because unless things have changed they don't attract any VAT at all. Also because I had a feeling that even if there were any charges HMRC's doc's in all probability don't mention what they actually are. I found out that they were zero rated at the time from some one in the USA who asked a USPS agent. The tax free aspect seemed to apply to all major countries in the west.
                                      It's an area that might interest people who collect old microscopes.
                                      Really from my experience if some one wants to know specific details about import taxes it's probably best to phone up and ask them. There may even be different rules for gifts and commercial samples.
                                      Ajohnw
                                        @ajohnw51620
                                        Just a note for any one who buys lenses from Astromedia. The lenses are coated as they state but that isn't immediately apparent. They are broad band and don't really have any colour at all. Some colour can be seen by looking at the reflection of a fluorescent strip light at various angles. This happens because the thickness of the coatings is what gives them the anti reflection property so at some angles it appears thicker as far as light is concerned and the surface will reflect.
                                        surpriseSome one bought one and thought it wasn't coated. Actually I think it's a fairly high quality coating.
                                        The other way to tell is to compare the reflection off them with a plain piece of polished glass.
                                          Posted by Ajohnw on 19/01/2016 18:22:24:
                                          What an oaf? eh
                                          #221759
                                          Ajohnw
                                            @ajohnw51620
                                            Actually Neil it looks like things can go wrong. I wanted a best form plano convex lens. The flat side is slightly curved. It's come and it's only coated on one side !
                                            Not sure if that is a one off or normal for this lens. It probably doesn't matter for what I want it for and I have to bear in mind it costed £2.58. Knightoptical would charge me 10 times that plus vat and probably a ridiculous postage price. Cheapest on ebay around £21.
                                              Now trying to think of an easy route to a 2" tube without butchering my 50mm/300mm scope just in case I find a use for it (guiding?)
                                              Probably end up paying as much for a bit of ally tube as the lens!
                                              N.
                                              #222154
                                              Ajohnw
                                                @ajohnw51620
                                                You might find a microscope graticule eyepiece useful Neil. 10x should have a focal length of 25mm. (250mm/X) They come in 2 sizes the smaller one will have a field of view of around 18mm or so. They tend to be a lot cheaper than astro eyepieces with them. This one is high eyepoint as well 261904055261 but the ordinary ones are ok.
                                                  I've got a cheap Bresser 20mm here which will give me a neat 9x.
                                                  I have to decide whether or not to butcher an old 50mm x 300mm scope – it has a 0.925" barrel with rack & pinion but I can bodge the eyepiece to fit. Trouble is that although the scope is an old cheapy, taking it apart shows it has a lovely coated airspaced achro doublet – it's just too long an FL for a finder. If I cut off a big chunk of the barrel it will spoil it as a 300mm scope :-/
                                                  Ajohnw
                                                    @ajohnw51620
                                                    You could just use rigid plastic plumbing pipe Neil. I'd buy a piece of tube. I would have thought there would be a metal supplier around where I think you are – near Burton on Trent?
                                                      Yes, thought of that – annoying how much I've thrown away over the years! I need a new toilet flush handle and one from the bay shows no signs of appearing so off to Wickes today..
