Workshop Break in
Workshop Break in
Home › Forums › Workshop Tools and Tooling › Workshop Break in
Viewing 25 posts - 1 through 25 (of 57 total)
  • #139052
    Kevin Bennett
      @kevinbennett25223
      Hi all the Police have just left after doing a 2 hour statement as some thieving F****** ?? Ba***** ?? has nicked my Clarke compressor from my workshop over night . I have very good security I think I had 2 good locks but apparently not
      they lifted it over a 5 foot gate all I can say is I hope it chokes them.
      all the things I want to do the police say I cannot do as I will have to do time in the nick even carpet gripper on the fence
      the strange thing is it was the only thing that was taken all my other left tools off to the DIY store for more security bits and bobs
      any suggestions
      #17253
      Kevin Bennett
        @kevinbennett25223
        Workshop Break in
        #139054
        _Paul_
          @_paul_
          Bummer, strange only one specific item, pinched to order?
          Wickes have 120w Security lights for £7
          Cheap cordless alarm or fake alarm box and or cameras real of fake.
          Paul
          #139055
          Bazyle
            @bazyle
            Comiserations – that is a really miserable thing to have happen over the holiday period.
            Here is a piece of text I prepared originally for another forum but never posted when the thread degenerated into a load of gun talk.
            Section 1
            Starting outside in the road the absence of a car in your drive might show you are out, removes the physical block to opening the garage door once that puny lock is broken, and allows a big van to park there hiding the act of breaking the lock and shovelling your stuff straight into the back.
            A neighbour might agree to park in your drive when you are on holiday.
            Moving to the side gate into the back yard is it easy to climb? Horizontal bars, boards or frames make handy footholds that close vertical boards prevent. Even the hasp and padlock on the outside at waist height are a convenient step. An open top, even at 6ft is no barrier – 8 to 10ft is more like it. A flimsy structure up above the gate may be better than a rigid one that acts as a climbing frame. Having established that glass shards and barbed wire is not legal in some countries get a thorny rose to climb over the frame.
            Now walking down the path one of crunchy gravel is off-putting to an intruder trying to keep quiet. However some paving stones are valuable if made to rock by ¼ inch, biased one way. Fit a contact switch (magnetic = waterproof) under the stone and something like a flower pot or kids toy “randomly” on the down end to encourage the intruder to step over onto the tipping end.
            Magnetic switches can be placed under pots, toys, and tools that might be kicked aside, or attached to ‘twigs’ sticking out of a bush, all to detect the presence of an intruder before damage is done.
            Closer to the shed roses, thorns, pyrocantha and similar shrubs provide barriers to funnel visitors to a protected route.
            The shed itself needs to be a bit more than flimsy weatherboard. Outside 4 in mesh ‘hog wire’ stapled every 6 inches holds the boards together making removal more difficult while looking like it was just put there for that thorny rose to climb over. Inside the layers of insulation and lining also add to the difficulty of hacking through the wall. Don’t forget the roof which is often a weak point and if possible go for corrugated iron with some bolts right through inside to big washers.
            The window, if you must have one, needs some 2 in weldmesh but then arrange a simple external hinged shutter too. Now we start on the decoys. Make the shutter latch just a toggle, no lock. When opened, a magnetic switch can set the alarm off without any damage having been done. If it had been locked it would have just been another thing to repair without having actually prevented entry.
            Now we have got to the door. Not the pathetic panel on so many garden sheds. Build a strong frame and a solid door. If the door opens inwards put a screen door on the outside even if you don’t need it.(that’s a fine mesh door to stop flies that has become less common now we all have aircon). This screen door is another trap having no lock it has to be opened before trying to break the real door – and it sets off the alarm.
            If your door opens outwards the screen doesn’t fit so put a simple hinged bar across the door with a padlock hasp. It looks like you fitted it as extra security but forgot to put the padlock on today – move it and off goes that alarm.
            #139058
            Bazyle
              @bazyle
              Secton 2
              We are finally at the door itself. It has a nice tempting lever handle – push that down and what happens is anything other than open the door. Pull it and it comes right off in your hand also releasing alarm contacts. You had a rubbish 4 lever lock on the door? Leave it on, locked, but saw off the actual bolt and leave the key ‘hidden’ under a flower pot. If picked or unlocked the back end of the bolt can bear against a switch.
              So with handle and lock as decoys how is the door held? Well you’re an engineer aren’t you? Make a 4 or 6 point linked bolt mechanism holding all 4 sides. So where is the handle to operate that mechanism? Not on the door of course. Universal joints or bowden cables connect somewhere less obvious where there isn’t even a handle. The handle is removable and is normally stored as the handle on a broken umbrella in the hall cupboard. That handle if fitted and rotated normally does nothing as the way the lock works is to connect the handle to the bolt mechanism. Fit a 5 or 6 lever lock somewhere with a non obvious keyhole hidden behind a bird feeder or light fitting. The key isn’t just as provided. Weld it to a 6 in extension and set the lock well out of range of normal lock picking kit. If you happen across an old cylinder lock mechanism put it in the door too but no need to actually connect it to anything. Just something for the would be intruder to waste time on.
              If you go away for a few days pile some old bits of timber, logs etc and the old wheelbarrow agains the door to make it look like it isn't used anyway. Or perhaps a garden table piled with pots.
              Inside there is the obvious PIR sensor.
              So far all these alarms have to be turned off to gain legitimate entry and might accidently be left off. Inside you can have another couple of permanent circuits. One on a cupboard you rarely need to open. If that cupboard door is glass or mesh to show that inside is something tempting then so much the better. Arrange that the circuit can be temporarily bypassed by a hidden sprung switch that allows you to open the door but can’t be left off. Another circuit can be permanently on if you can train yourself not to touch a certain object in prominent view. What looks tempting? Perhaps a shiny brass bar, or a 50$ bill with a brass bar on it as a paperweight?
              Well that’s a few ideas to be gong on with. You might not fit them all but even a couple will give you peace of mind.
              #139059
              John Stevenson 1
                @johnstevenson1
                Bazyle,
                Check your PM, i have had one to you waiting for a couple of days unread.
                #139060
                DMB
                  @dmb
                  Bayzle,
                  Well done! Never thought of traps like apparently unlocked security measures that trigger alarm as soon as they are touched.
                  I have a back entrance gate of mainly vertical steel rods. Its surmounted by “natures barbed wire” – Pyracantha, aka “Firethorn.” Wicked 1″ long hard wood thorny spikes! Not illegal like anything man made. Back wall 6′ high covered in Ivy laced with the Firethorn!
                  Not had intruders since that lot grown. I used to have a neighbour constantly entering back garden whilst I was at work. That suddenly stopped after I fitted a trip wire at ankle height across the path, apparently to hold 2 garden plant posts. Said neighbour later seen with arm in plaster!
                  #139061
                  DMB
                    @dmb
                    My shed is double skinned for insulation purposes including the door. Although door has usual shed hinges some screws replaced by round headed bolts with large washers preventing them being wrenched through the wood and 2 nuts lightly screwed up but very tightly locked together so they will turn round for ever but not unscrew. Alarm + security light. No “beware the dog” but just rather more subtle signs of a dog. Also have further securiy measures not being discussed. Security is about not revealing all precautions!
                    #139070
                    websnail
                      @websnail
                      Posted by DMB on 29/12/2013 22:17:38:
                      Stealth is always best.
                      Security works better before it's needed too.
                      Everybody should take a look at their own security, both home and workshop periodically.
                      #139073
                      jason udall
                        @jasonudall57142
                        Hmm..another use for that pickle bath
                        #139078
                        RJW
                          @rjw
                          Perhaps the tank will suddenly develop a serious stress related fracture and catastophically disintegrate a nano second before the pressure switch shuts off the motor, with a bit of luck the thieving trash will be bending over it at the time ……… we can dream eh!
                          A chap I knew had a very simple anti-theft device on his shed to protect his Fireblade, he rigged up a hidden trip wire just inside the door, which when caught activated a device to fire a blank shotgun cartridge at head height, personally I'd be too tempted to fill it with shot!
                          John.
                          #139086
                          ronan walsh
                            @ronanwalsh98054
                            I was having trouble with local young scrotes climbing over our back wall (6ft) and messing with things, they never took anything but it was only a matter of time before they decided to help themselves. As a firearm licence holder the police have to inspect my security, and when they did i took the opportunity to ask what i can do , legally to make the place more secure.
                            Spikes or broken glass set in cement on the wall tops are a big no-no. Not only will the lowlife take the chance to sue you if they hurt themselves while robbing you, it can put your property at risk firemen will not climb over broken glass to put out your fire.
                            The solution was a trip to a local lorry yard and obtaining from them a nice big tub of filthy used axle grease. Smeared liberally all over the wall, it works at keeping opportunist lowlife out and makes the more hardened criminal think twice too. The police did tell me thieves deliberately search for weak targets and slack security.
                            I would also suggest cctv, its easy to set up now and the cameras are available cheaply, even from aldi. Recorded cctv footage can be backed up on the internet, making tampering with it impossible. Apart from that, plenty of steel bars or grilles in windows , heavy bolts and good locks, and a noisy dog if you like, is the way to go, sadly its a sign of modern times.
                            #139088
                            Ady1
                              @ady1
                              There's one thing scallys always stay away from
                              Dogs
                              Scope out place A and place B
                              Place B has a dog…
                              ….guess who gets done?
                              Now they know your layout and what's in there…  there's a high probability they'll be back too
                              Edited By Ady1 on 30/12/2013 01:09:33
                              #139091
                              I.M. OUTAHERE
                                @i-m-outahere
                                I can sympathise with your loss as I had the same sort of equipment flogged a few years back.
                                They cut through the hasp with a set of bolt cutters and bent it to release the lock , unplugged my air compressor hose from the impact gun and rolled up the hose and wheeled it out leaving the impact gun on a stool !
                                Then locked the shed up again by bending the hasp back and setting the lock up so it covered the cut .
                                Must have planned to come back but after I discovered the theft I made a heavy hasp and staple unit from 3/8 inch stainless and made it so it covered the whole lock with a housing so they can't cut the lock.
                                Everything with wheels was chained to something heavy or to a lug dynabolted to the ground and anything that could cut the chain was locked in a heavy tool box .
                                A cheap alarm was fitted also.
                                I would suspect that my compressor was converted into drugs and all I could hope for was for the mongrel to overdose and croak .
                                One other thing that a friend of mine is always on about and that is Don't advertise !
                                If you go inside for lunch etc close the door so no one can see inside and this is especially true if you can see into the workshop from the street or a lane .
                                Ian
                                #139092
                                FMES
                                  @fmes
                                  Post deleted at request of member by JasonB
                                  Edited By JasonB on 31/12/2013 16:17:27
                                  #139097
                                  Mike Teaman
                                    @miketeaman64279
                                    Beware the person who knocks on your door who claims to have broken down "up the road" and needs a couple of spanners and a screwdriver! How many of us, trying to be helpful, will take them straight to our toolshed?
                                    #139098
                                    SteveW
                                      @stevew54046
                                      Also have a look at Google Streetview. My garage was shown with the door open revealing my drill and lathe! Good news is that they will remove image or grey it out on request. We are also hounded by scrap men just.about 24hrs service
                                      SteveW
                                      #139103
                                      Tony Pratt 1
                                        @tonypratt1
                                        Posted by Lofty76 on 30/12/2013 06:39:07:
                                        Are you sure that is right, can you locate my home address from my email?
                                        Tony
                                        Edited By JasonB on 31/12/2013 16:18:20
                                        #139108
                                        Jo
                                          @jo
                                          Yes make things very secure but a determined thief will always get in and once they know you are an opportunity they will come back for more .
                                          Assuming that no one in the area knows you have a workshop or your hobbies (sadly this is where helping out neighbours is not such a good idea) then they are likely to be opportunist thieves, so they will round here they steal lawn tractors, in urban areas DIY tools seems to be the rage. If you don't want them turning everything upside down then a few easily replaceable items on show will save a lot of grief for those items that are irreplaceable.
                                          If the thief knows what you have and are stealing to order then they will come prepared for any level of security. There was one case where they lifted the roof of someone's workshop and craned out his locos/machine tools. It was so obvious that no bypasses questioned if what they were doing was legitimate.
                                          Jo
                                          #139110
                                          MICHAEL WILLIAMS
                                            @michaelwilliams41215
                                            Hi Kevin ,
                                            Sorry to hear of your problems .
                                            Since one specific item was taken and other probably higher value items left I think that there is a high probability that the compressor was stolen to order .
                                            This is a very common type of crime . Someone wants a compressor – someone else knows where there is one – deal done for cash .
                                            You may like to try doing a logic tree – plot out who could have known and see what connections you can establish to them .
                                            When equipment is lost it is not always gone very far and it might become visible again sometime .
                                            Trouble is if you want to claim it and bring prosecutions one compressor looks like another so difficult to establish a legally sound identification .
                                            Best thing to do is mark all your more valuable things with some information which positively identifies them .
                                            Serial numbers can be altered and erased so basically no good .
                                            Some better options are :
                                            A complex but meaningless pattern of scratches underneath where no-one will look – photos’s kept .
                                            Random pattern of paint splashes which is unique but meaningless to casual observer or
                                            a smart looking painted logo which looks like it belongs there but which is in fact your personal identifier .
                                            In any case keep photos of all valuable items both for tracing and insurance claims .
                                            Signature in invisible paint or magic water .
                                            I positively don’t recommend practice described below because it’s both dangerous and illegal but I believe that this is a true story :
                                            A man that my late father knew quite well many many years ago ran a civil engineering business – usually doing / sewage / gas / water major works for local authorities . His yard was in middle of knowhere and he of nescessity used many transient workers . Theft was wholesale and included industrial compressors and even JCB’s .
                                            The man heard rumours that there was a pub where people dealing in stolen property could be found . He went there one night incognito and bought his JCB back .
                                            Regards MikeW
                                            Edited By MICHAEL WILLIAMS on 30/12/2013 11:09:08
                                            Edited By MICHAEL WILLIAMS on 30/12/2013 11:10:49
                                            Edited By MICHAEL WILLIAMS on 30/12/2013 11:14:12
                                            #139112
                                            NJH
                                              @njh
                                              | "There's one thing scallys always stay away from
                                              Dogs"
                                              How true!
                                              I used to live on the outskirts of a town in a house with a longish garden. I had two pet Staffies and their routine last thing at night was to hurtle down the garden barking furiously in the futile hope of catching some unwise cat in the garden. One night there there was more barking than usual and they didn't come in so I went outside to check. Between my garden and the neighbours were 6ft high interwoven fence panels – in one of these there was a man sized hole!
                                              Norman
                                              #139116
                                              JA
                                                @ja
                                                Following on from Michael William's comment (sorry for not quoting) I had a friend, a forensic scientist, who gave the following advise for marking property (it this case motorcycles). Find an area of metal, ideally steel, remove the paint and stamp into the bear metal identification letters (post code will do). Then gently file the surface back so that the letters disappear and repaint. When it comes to reading the identification scrape the paint off, polish and etch the metal. The letters will be easy to read in a good light. This will work on unpainted aluminium.
                                                The main reasons for doing this is that the courts will not accept identification by any old marks that could be the result of normal wear and tear and that the identification mark cannot be detected by the thief unless he already knows it is there.
                                                JA
                                                #139128
                                                FMES
                                                  @fmes
                                                  Edited By JasonB on 31/12/2013 16:16:32
                                                  #139129
                                                  Kevin Bennett
                                                    @kevinbennett25223
                                                    hi thanks for all the comments got a alarm today and some steel make a door bar
                                                    I am still gutted the someone has been in my space I was surprised that it was only the compressor that went as I had 2 Stuart engines on the bench.
                                                    this the door bar I am going to fabricate and mark all my tools  if possible
                                                    ty kevin
                                                    Edited By Kevin Bennett on 30/12/2013 12:45:02
                                                    #139131
                                                    Lambton
                                                      @lambton
                                                      Paul is right.
                                                      Some years ago I was in charge of the workshops at an engineering company in a large town in north Northants. We suffered several break ins each year. It seemed strange to me that items stolen appeared to be selected at random and brand new items such a Bosch power drill were left alone. When I raised this with the workshop staff they were incredulous that I did not know that only things that the thieves had orders for would be stolen. The reason being they moved the items on within minutes of leaving the building so if the police, who knew all the local villains, caught up with them they would not have any stolen property "in stock" to incriminate them. I was assured no regular local thief would take anything speculatively.
