Hi all.
Sort of a question, do you use your ER collet chuck in the mill to drill holes or do you put a drill chuck in?
Been doing a few bits with the new mill, mainly brackets and motor mounts for the powerfeed and I am finding it easier and quicker to use the ER collet chuck to hold the drill bits rather that change to the drill chuck, one reason is the R8 arbour on the drill chuck is very tight in the spindle, it goes in easy but is a bugger to remove, so much quicker to swap collet (I have all sizes from 1mm to 20mm)
Now is it the done thing the way I do it or is it shunned upon?
Does anyone else seem to spend more time tidying up the workshop than actually working in it?
Granted I'm a messy worker and the inside of the mancave is not finished (insulation and internal panels) so the three 8' benches were put in but I have no real hand tool storage and I have a lot crammed into it (mill, mini lathe, drill press, 10" cabinet saw/router table, blasting cabinet, compressor, dust collector, belt sander, bench grinder, bandsaw, computer with twin monitors, all on the benches/floor standing plus a tig welder, mig welder, small planer thicknesses, mitre saw, morticer,another bandsaw under one bench and shelving under the other 2 with all the power tools under one and hardware under the other.
I do have a small roller tool chest that I need to sort out so my hand tools tend to live on whatever bench or horizontal surface is available!!!
My mancave is 10' x 20' timber construction, I built it about 18 months ago at the end of the garden with 3 feet behind it (10' end) so I'm going to put part of the old shed I have in pieces in the gap on the end to house the dust collector and compressor (both noisy buggers) and a rack to store long materials.
