Word to the Wise
Word to the Wise
Home Forums Beginners questions Word to the Wise
  • #4978
    Sub Mandrel
      @submandrel
      Sub Mandrel
        @submandrel
        Oops…
        I finally got around to making the jacking screw for a little machinist jack tonight. I found some free cutting stainless steel that comes up to a bright polish and thought it would make a good contrast to an oil blacked base.
        Well it cut wonderfully, creating long single curls of swarf, nice surface finish, with a 20 thou (0.5mm cut).
        But could I get an HSS M6 die to cut it? Barely. I took off a 5 thou to ease things for the die and it got worse, I had obviously really badly workhardened the surface.
        So I switched over to some tougher steel, EN24T at a guess. the surface finish was awful, so I thought I’d better sharpen the tool – that’s when I noticed it was a flat topped tool for brass with zero rake.  No wonder it workhardened the stainless!
        Moral – don’t assume you have the right tool in the toolpost , even idf it looks right at a glance!
        Circlip
          @circlip
          Key word there Neil,  ASSUME???????
             Regards  Ian.
          #49147
          Ian S C
            @iansc
            Hi Neil,been there done that, thought that seeing stainless is so tough I’d take the thread down in stages with a die, first cut OK, second cut? nothing came off. Cut the threaded bit off, set the die to full depth, good thread, cut once you don’t get a second go.Ian S C
            #49148
            DMB
              @dmb
              Hi Neil,
              May I suggest that any tools to cut Brass, you clour witha dab of yellow paint?
              I use those small pen type touch-in paints sold for cars and colour-code an awful lot of things, e.g., caphead screws and the fitting Allen key as I always seem to pick up the wrong size. I also dont believe in complete sets of spanners on walls like some “show – workshops” seen in the mags. I find it much more convenient to have `dedicated` spanners in a box/rack special for the mill or for the lathe. Even these I colour one end so if they end up on the bench, I know instantly where they belong when I have a clear-up.
              John.
              #49230
              Sub Mandrel
                @submandrel
                Posted by Circlip on 25/02/2010 07:42:05:
                   Regards  Ian.
                You know, my wife keeps saying just that!
                Good idea, I’ll do something like that. I also try to keep some ‘favourite’ tools to fit the various machine tools. But the little men keep hiding them under the bench!
