Wooden Gears
Wooden Gears
Home Forums Traction engines Wooden Gears
Viewing 25 posts - 26 through 50 (of 56 total)
  • #480122
    Bo’sun
      @bosun58570
      As I understand it, most woods will carve or cleave better when they're green, as the cellulose in the structure is still essentially liquid. As the wood dries out, the cellulose hardens and the moisture dries out, gluing the cells together, making some timbers like concrete.
      Nicholas Farr
        @nicholasfarr14254
        Hi, just for interest, this was a display at the 2017 MMEEX. I don't know if it was aimed to be a static display or whether it was a working model. I guess it could only have one fire up display though. smile
        Regards Nick.
        #491860
        Roger Best
          @rogerbest89007
          Plywood gears? – no problem.
          Edited By Roger Best on 22/08/2020 01:03:00
          #491861
          Hopper
            @hopper
            Posted by Michael Gilligan on 15/06/2020 12:38:48:
            A philosophical question, which probably only Mick H’s son can answer:
            Does ready-made ply qualify as ‘wood’ ?
            … or, as an ‘engineered material’ would its use be considered cheating ?
            Well it's called plywood.
            #491867
              Posted by Hopper on 22/08/2020 01:38:42:
              Or you could put the emphasis on ply instead of wood
              It is an ‘engineered material’ constructed from wood.
              … Hence my question.
              Hopper
                @hopper
                Is a boat made from marine ply a wooden boat?
                #491875
                  That probably depends upon the the constructor’s and/or the examiner’s opinion.
                  … Which was the very essence of my question:
                  Unless you happen to be Mick H’s son … can we leave it at that, please.
                  #491889
                  Hopper
                    @hopper
                    Enquiring minds want to know.
                    #491899
                      O.K. … if you must labour it, Hopper
                      My personal opinion is that factory-made plywood does not qualify as wood.
                      The reason for posing my question was that [not knowing Mick or his Son, or the circumstances], I am not aware of whether this is a ‘fun project’ or a ‘design & manufacturing’ exercise. … It may, for all I know, be subject to assessment.
                      Many years ago, I made some hair-slides for my wife : These were laminated, by me, from layers of wood veneer.
                      As such : I would say they were (a) made from wood, and (b) demonstrated my understanding of how wood can be ‘engineered’ to make better use of its characteristic properties.
                      IF the gears in question are to be ‘assessed’ then I would expect the ‘plywood’ to be manufactured, not bought-in, by Mick’s son … to demonstrate his understanding.
                      Your opinion may differ, and I respect your right to hold it
                        I hope you cut your own veneers Michael as bought in would see you loose a few pointswink
                        Which brings up the question of where to draw the line between "factory-made" and home made, should Mick's son be buying in prepared timber, cutting from sawn boards or starting with green wood and planking and drying his own?
                        #491909
                          All of which takes me back to my original:
                          [quote]
                          [/quote]
                          #491911
                          pgk pgk
                            @pgkpgk17461
                            …or planting the trees from hedgerow harvested seed..
                            …then you have the problem of glue, rearing your own animals to harvest the hooves…
                            ..or pine resin glue
                            pgk
                            Edited By pgk pgk on 22/08/2020 10:38:20
                            #491914
                              Posted by Michael Gilligan on 22/08/2020 09:29:12:
                              PostScript: For use in wooden gears, I would also hope to find some of the plies to be arranged as ‘pie segments’
                              ega
                                @ega
                                The pie segments approach would also serve for a wooden pulley.
                                Pine resin: is the YouTuber right to call it epoxy?
                                #491922
                                Gary Wooding
                                  @garywooding25363
                                  Posted by pgk pgk on 22/08/2020 10:37:46:
                                  As somebody once said, "If you want to make an apple pie from scratch, you must first create the universe".
                                  #491942
                                  Roger Best
                                    @rogerbest89007
                                    The issue is making the best of the resources available, not being restrictive; innovation is king in the real world.
                                    I say ply is wood enough. wink
                                    #491945
                                    Howard Lewis
                                      @howardlewis46836
                                      So far, no one has mentioned MDF. It has no grain, but the dust is reputed to be pretty nasty.
                                      Or it totally out of court mas not being real wood, instead of ,as I understand it, resin bonded wood dust?
                                      #491946
                                      pgk pgk
                                        @pgkpgk17461
                                        Posted by ega on 22/08/2020 10:52:38:
                                        Epoxy is probably millenial-speak for glue crying
                                        pgk
                                        #491964
                                        ega
                                          @ega
                                          Posted by pgk pgk on 22/08/2020 12:48:16:
                                          pgk
                                          A "respectful" virtual elbow bump to you for being in touch with youth!
                                          The dictionary says "synthetic" resin but does that preclude epoxy resin from occurring in nature?
                                          I am reminded that petrified resin becomes amber which is not unlike a blob of cured Araldite.
                                          #491973
                                          Tim Stevens
                                            @timstevens64731
                                            Whatever wood you decide on, you need to understand that wood is strong along the grain, but weak across it. That is why plywood is mentioned above. In practice, making your own from layers of veneer might be best.
                                            And then you need to work out how to cut the teeth without destroying the outermost edges. Once you are sure that the laminations are properly stuck together and waterproof, it would help to add an extra sacrificial layer both sides using a water soluble glue, cut the teeth ignoring the fact that bits flake off, then soak off the outsides.
                                            Good luck
                                            Tim
                                            Edited By Tim Stevens on 22/08/2020 15:31:17
                                            #491980
                                              Though given the ease at which wood can be cut with a router and a lot of schools have small CNC routers then with a small dia cutter the gear could be cut flat with the tool following the path of the teeth rather than using a cutter at right angles to the gear. With an up/down shear cutter you won't even risk any tearout, also known as compression spiral cutters.
                                              Edited By JasonB on 22/08/2020 16:12:43
                                              #491984
                                              Tim Stevens
                                                @timstevens64731
                                                An alternative gear-tooth cutting method, if you can access the kit, would be to draw out the gears in a CAD program and get them laser cut. This method uses a hot beam of light across the gear, so there should be no tendency to tear at the grain.
                                                I think there are adverts in MEW for this sort of service.
                                                Cheers, Tim
                                                #491994
                                                John Haine
                                                  @johnhaine32865
                                                  If MDF is a possibility then you might also consider Valchromat, which is a similar product but using a melamine resin rather than formaldehyde. It machines very well, better tha MDF, and is much safer.
                                                  MDF can be sealed and strengthened by "varnishing" with PVA slightly diluted, or possibly better is a Ronseal product for treating wet rot, which is a resin dissolved in a volatile solvent. This soaks readily into the material without making it swell, then dries sticking all the fibres together making it much more resistant. Either would probably be suitable for Valchromat as well.
                                                  In boatbuilding plywood (and other woods) are treated with a liquid epoxy resin which soaks in and seals it, also making it much stronger. Look up "West System Epoxy".
                                                  Edited By John Haine on 22/08/2020 18:13:44
                                                  #492099
                                                  Georgineer
                                                    @georgineer
                                                    Posted by Tim Stevens on 22/08/2020 16:43:16:
                                                    Cheers, Tim
                                                    My personal objection to this would be an aesthetic one, because the cut surfaces are scorched black.
                                                    George B.
                                                    Edited By Georgineer on 23/08/2020 11:54:05
                                                    #519216
                                                      Resurrecting Mick’s thread, because I think this may be of general interest:
                                                      https://www.hodinkee.com/search?q=wooden+wheels
                                                    Home Forums Traction engines Topics
