If you are making a 'strip planked' canoe, you se the bead and cove.
these boats are made from 1/4*3/4 cedar, generally, and each strip is prepared are with a 1/4 dia bead on one side and matching cove on the other. This lets them be snugged together as they go around the curve of the station moulds. Once on, sand outside smooth.
having built a couple of these, I reckon the tooling design is poor and the beads need to be more like 5/16 or 3/8 diameter as matching the wood thickness and diameter means you run into problems on tight curves.
would not be hard to do this for cleading- I am about to do one and hadn't thought of this. Was going to do a coopered approach (wedge shaped cross section) which is less tolerant of error.
again, based on canoe experience, the cove is harder to get right than the bead. If you were to apply the cove before cutting the strip it might be under better control. At this scale, scraper will be more than adequate if you watch grain direction. Look for a piece of timber with a slight consistent grain run out along the edge, rather than one too perfect- counter intuitive, but you will get a better result more easily and strength is not an issue here.
i have to confess that I do still do a fair bit of woodwork in spare time, it is not as scary as some think!
