WM250 V lathe change gears
Home Forums Workshop Tools and Tooling WM250 V lathe change gears
  • #586932
    Bernard Reilly
      @bernardreilly64467
      Hi all can any owner of a Warco WM 250 or 250V lathe inform me of the change gear module No for this lathe.
      Thank you Bernard Reilly Glasgow.
      Bernard Reilly
        @bernardreilly64467
        #586946
        Thor 🇳🇴
          @thor
          If you have access to a gear, the Outer Diameter is:
            Outer Diameter = (Number of teeth + 2) x Module
          and the Module:
            Module = Outer Diameter / (Number of teeth + 2)
          Thor
          Edited By Thor 🇳🇴 on 23/02/2022 18:39:19
          #586948
          Mick B1
            @mickb1
            Grabbing a gear at random from the metal box that came with mine, I get:
            97,47mm/(63+2) = 1.4995 – presumably 1.5
            #586954
            Tony Pratt 1
              @tonypratt1
              Hi Bernard, are you looking to buy some gears? If so I have a set which was supplied with my Warco 290V not used & surplus to requirements.
              Tony
              #587335
              Bernard Reilly
                @bernardreilly64467
                Thanks guys for info received I have now made contact with you- engraving to supply 4 off Delrin gears to suit my WM250 V lathe.
                .Bernard Reilly Glasgow.
