In case the same scenario befalls anyone else….
i have a Compact 5 which is a nice machine but suffers from a tediously unfriendly and slow speed change mechanism using the original motor. When I was offered a second hand Telematique Altivar 11 inverter cheaply albeit with a 'no proof of functionality' label, I took it since it would avoid all (most) belt changes.
I then bought a brand new 3 phase motor from Germany through eBay with a similar rating to the old one in the same frame size which arrived Wednesday.
A couple of hours wiring including the remote speed and forward/reverse switches and setting the motor connections from Star to Delta and I was ready to run.
Power up resulted in a nasty noise reminiscent of a slipping stepper motor and some motor vibration but no inclination to run at all. Several hours checking the parameters on the inverter as well as all the wiring left me thinking that it 'should' be ok, especially since it was not reporting any error condition.
Turning to the motor, I disconnected it and checked the 3 windings, which showed 2 x open circuit and one at 20 ohms. Not really believing that I had blown 2 windings in the space of a couple of hours, nor that it was supplied faulty, I returned it to the original Star connections. Result, 3 windings with 20 ohms each…
a very much closer look at the windings revealed that they had been incorrectly wired such that the normal Delta strap connections had simply shorted out 2 windings, leaving a single winding to rotate the motor…In Star mode, the problem was masked thanks to the common connection.
The moral of the story? Don't assume that the fault lies in the unproven, second hand item, do check the brand new components as well…
