Wiring a VFD to a foot switch?
Home Forums Electronics in the Workshop Wiring a VFD to a foot switch?
Viewing 25 posts - 1 through 25 (of 45 total)
  • #32311
    wayne ollerenshaw
      @wayneollerenshaw89933
      wayne ollerenshaw
        Hi all
        Got a project here that needs a foot switch wiring to a single phase motor with a VFD. Usual cheap chinese one as below.
        Is this possible?
        https://www.ebay.co.uk/itm/393329744803?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=fX8V16uPTo2&sssrc=2349624&ssuid=Wi78z-7jSx-&var=&widget_ver=artemis&media=COPY
        It will be a off/on/off switch. So put foot on switch then telease to stop the motor.
        Thanks Faffer
        Edited By wayne ollerenshaw on 12/01/2023 18:11:14
        #628910
        Oldiron
          @oldiron
          Cannot see a problem with that. It is no different than adding a remote pendant but just connecting the on off switch.
          Only downside I can see is that I dont think reverse will be possible just using the foot switch.
          regards
          #628915
          Emgee
            @emgee
            Hi Wayne
            You will need to check in the electrical instructions to find if the start/stop paramaters provide 2 wire control for the simplest solution.
            Emgee
            #628923
            old mart
              @oldmart
              VFD's are usually started by momentary off to on or on to off switches. The common switches usually have the choice when you wire them, you will need to see if the foot pedal works like that.
              #628929
              noel shelley
                @noelshelley55608
                single phase motor and VFD ?
                #628934
                old mart
                  @oldmart
                  I missed that, Noel, maybe a sewing machine pedal would work, no need for a VFD.
                  #628946
                  Ian P
                    @ianp
                    Posted by old mart on 12/01/2023 19:55:24:
                    Many, or probably most, VFD's can be set up or programmed to work with momentary or latching switches.
                    Ian P
                    #628953
                    wayne ollerenshaw
                      Posted by noel shelley on 12/01/2023 20:09:06:
                      Yes I have a motor I want to alter rpm/Hz.
                      I do have instructions somewhere from.another VFD I fitted just can't find themamd don't want to go buying another incase I can't run the motor from a VFD with a foot switch.
                      I was thinking on using a sewing machine pedal aswell
                      .my last sewing machine only had two wires going to it. It was an old Reeds.
                      I know the VFD can be set up for all sorts and dead.stoppong which I want aswell
                      Thanks for the help aswell
                      #628978
                      Anonymous
                        The point Noel was making is that some single phase motors have poor performance when run from a VFD, and many types of single phase motor simply won't work with a VFD. Ideally you need a shaded pole or permanent split capacitor motor.
                        Edited By Andrew Johnston on 12/01/2023 22:22:11
                        #628990
                        Ian P
                          @ianp
                          Posted by Andrew Johnston on 12/01/2023 22:21:54:
                          Ideally, you need a three phase motor with the VFD if you want a usefully wide range of speed control.
                          Ian P
                          #629008
                          wayne ollerenshaw
                            This is only a tester to see if what I am doing works so I can get a 3phase later if need be.
                            This is the motor I am using now though.
                            https://i.postimg.cc/MGbSsKmc/IMG-20221223-WA0000.jpg
                            #629009
                            wayne ollerenshaw
                              #629064
                              wayne ollerenshaw
                                Ok just seen these forn the speed control. Which can
                                .I think be easy wired.to foot.control..
                                This will.do away with a VFD which is more complex
                                The motor is 0.55kw so under the 4kw speed.controer.
                                How does that sound
                                https://www.ebay.co.uk/itm/394417395091?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=v6hzlpy9s_a&sssrc=2349624&ssuid=Wi78z-7jSx-&var=&widget_ver=artemis&media=COPY
                                Edited By wayne ollerenshaw on 13/01/2023 13:38:10
                                Edited By wayne ollerenshaw on 13/01/2023 13:46:11
                                #629066
                                Anonymous
                                  Sigh, the unit is a thyristor phase angle voltage controller. It does not change frequency so will not change the speed of an induction motor. As an aside note that the 4kW rating is for a resistive load, which a motor certainly isn't.
                                  It would be much better to tell us what you want to achieve and then those forum members who understand the technology can advise on the best solution.
                                  #629069
                                  Les Jones 1
                                    @lesjones1
                                    Looking at the information in the advert for the VFD I can't decide if there are two different versions of the VFD or the same version can be used with either three phase or single phase motor. The picture with a singe phase motor seems to connect the main winding to one phase and the start winding to another phase. (I assume that the capacitor that is normally in series with the start winding is removed.) Can you post the manual for the VFD so we can see if any configuration settings need to be changed.
                                    Les.
                                    #629071
                                    Clive Brown 1
                                      @clivebrown1
                                      If it's to be of much help,I hope that any VFD manual that might be provided is written in better English than the tortured text of the eBay listing.
                                      Edited By Clive Brown 1 on 13/01/2023 14:34:41
                                      #629072
                                      duncan webster 1
                                        @duncanwebster1
                                        I thought you weren't supposed to have a switch between a vfd and the motor, but a single phase motor often has a centrifugal switch on the start winding. If you bypass that, it will might overheat, as not continuously rated
                                        #629078
                                        peak4
                                          @peak4
                                          I'll stand to be corrected, as the later models might allow different facilities/programming.
                                          I think you need an AT2 VFD, rather than an AT1, though some of the cheaper ones all use the same manual/datasheet and you need to extract the correct information yourself/
                                          The way it used to be
                                          AT-1 220v single phase in ~ 220v three phase out
                                          AT-2 220v single phase in ~ 220v single phase out
                                          AT-3 380v three phase in ~ 380v three phase out
                                          AT-4 220v three phase in ~ 380v three phase out
                                          For the AT-2 I think there are different wiring and programming parameters, depending on whether there is a start capacitor/switch remaining in circuit.
                                          I do know someone who uses/used AT-2 on a single phase motor, but his demo is on a closed Facebook group for home made belt grinders.
                                          He claims it's smooth from 20Hz-160Hz on a 4 pole motor, but said that torque dropped off at about 3750rpm.
                                          Before people start shouting about over-speeding motors, he's checked for what speed they were originally balanced, and doesn't advocate going to 160Hz; this was just an experiment as he had the kit in stock and not a recommendation for others.
                                          If you're buying new, or even second hand for a project, go for 3 phase to start with
                                          Bill
                                          Edited By peak4 on 13/01/2023 15:16:51
                                          #629084
                                          Ian P
                                            @ianp
                                            Whilst I knew there were some variable speed inverter type controllers available, I understood the concensus was that they had limited speed control and were of dubious value.
                                            These AT2 inverters look to be an answer for some situations. Whilst I am perfectly happy to continue with VFDs with 3 phase output, curiosity got me looking for an online AT2 manual, but I've drawn a blank!
                                            Just watched a youtube video of an AT2 being unboxed, but the box did not seem to contain any documentation.
                                            Has anyone got an AT2 or a link to its user manual?
                                            Ian P
                                            #629085
                                            wayne ollerenshaw
                                              Posted by Andrew Johnston on 13/01/2023 14:01:49:
                                              All I want to do is use the motor I have to run at lower speeds than the 1440rpm it is. Maybe as low as 500rpm. Also be used with a foot control pedal.
                                              If I can use a VFD, which one AT1 or AT2. Would be good to use the dead stop feature as I use on the o e on my lathe.
                                              The project is to fit a thick wall tube inside an outer tube thay is fitted to the motor spindle to use a grinder to do the job to round off the edges.
                                              #629086
                                              Robert Atkinson 2
                                                @robertatkinson2
                                                As Andrew has already said, the linked item IS NOT A VFD.
                                                This simple phase angle controller is not suitable for controlling a AC motor with variable load other than a "universal C/DC motor with brushes. I have seen them used to slow down fans with shaded pole motorss but only by increasing he slip.
                                                The linked item also looks positively dangerous and the outlet socket does not comply with UK regulations.
                                                Robert G8RPI.
                                                #629091
                                                not done it yet
                                                  @notdoneityet
                                                  +1. That advert clearly states “Variable Voltage Regulator”.
                                                  #629097
                                                  wayne ollerenshaw
                                                    Yes. Leave the controller I last linked to. I last posted about a VFD which I would rather use to ask Andrew on how I go about it.
                                                    #629104
                                                    peak4
                                                      @peak4
                                                      Posted by Ian P on 13/01/2023 15:39:57:
                                                      Ian P
                                                      Firstly, apologies for the typo in my previous post
                                                      AT-4 should read 220v Single Phase in ~ 380v Three phase out.
                                                      Do a simple Google search for AT2 inverter manual and pick the one from docplayer.net
                                                      https://www.google.co.uk/search?q=AT2+inverter+manual
                                                      It's the simple multi product manual that comes with the generic AT1~4 VFDs, and is the one which came with my AT1
                                                      This video is worth a look, which come from APO
                                                      Bill
                                                      Edited By peak4 on 13/01/2023 17:25:10
