Wire Bearings
Wire Bearings
Home Forums Workshop Techniques Wire Bearings
  • #15796
        These are unlikely to be found in 'our' workshops, but i thought folks might find them interesting.
        http://www.xreb.com/download/info/Wire-race_bearings.pdf
        Clive Hartland
          @clivehartland94829
          Wire bearings are found on Microscope translation stages and X and Y centring tables ( Small)
          #198517
          john carruthers
            @johncarruthers46255
            Handy to know, a mate wants an image rotator making for his robotic observatory, could be just the thing (depending on price).
            #198526
              Posted by john carruthers on 30/07/2015 18:31:54:
              Well that supplier says they design the bearing for each application individually so I suspect they are outside his range!
              john carruthers
                Ah well, back to the lazy Susan bearing
                #198571
                Brian Wood
                  @brianwood45127
                  The concept isn't new, but definitely clever.
                  I have an elderly Graul tool and cutter grinder, thought to be Swiss made, on which the toolslide is guided by a long row of captive balls in a linear brass spacer running between hard wires in pairs on either side. It is very free running, easy to adjust for taking up any wear and equally easy to clean if it gets contaminated in any way. I found it in a British Rail sale at their workshops in Darlington over 20 years ago and it was very definitely old then.
                  The movements for the other axes are rather more conventional.
                  #198585
                  Nigel McBurney 1
                    @nigelmcburney1
                    early hard drives with linear actuators had this type bearing
