Windows 11 Upgrade – non compliant machines.
Home Forums The Tea Room Windows 11 Upgrade – non compliant machines.
  • #786853
    Peter Cook 6
      @petercook6
      In case this is of use to anyone.
      With the impending withdrawal of free support for Win 10 in October, as the user of several perfectly functional machines which Microsoft says are non compliant, I have been considering my options. I have thought about going to Linux (but have several apps that would need Wine to keep working) or buying replacement hardware.
      However last week I decided to try a forced upgrade to Win 11 on a couple of machines using a freeware product called Rufus to create an upgrade  package that bypassed the compliance checks.
      Both machines are Microsoft branded tablets, one from 2013 and one from 2015. Neither have processors considered compliant. The 2015 machine does have compliant TPM V2.0 capability, but the 2013 machine is only TPM V1.2.
      Using the upgrade kit created, both machines successfully upgraded to fully activated Windows 11, although the newer machine needed me to dig around and remove a rogue device driver which caused the installation to hang. The older machine went through with no issues (albeit slowly). During the upgrade process you get a warning that you will not be entitled to updates, but as far as I can see the licence conditions don’t entitle you to them in any case.
      Both work just as well (and as quickly) as they did under Windows 10, so for those machines  the upgrade was the solution. I have a bigger desktop machine from the same era which has no TPM  capability and a none compliant processor – when we get nearer to October I may try the same trick on that.
      Roderick Jenkins
        @roderickjenkins93242
        If the fix to get W11 stops you getting updates, is there is there any point in changing from non-updatable W10 come October?
        Rod
        #786880
        David Jupp
          @davidjupp51506
          I must be missing something – apart from directing traffic to their web site, how does a link to a tool for making bootable USB sticks explain anything about updating to Win11 on non-supported hardware?
          Perhaps it is assumed that we are all familiar with whatever method is being discussed….
          #786884
          peak4
            @peak4
            There’s various articles in the press; try this one from PCMag
            https://www.pcmag.com/how-to/how-to-upgrade-to-windows-11-for-free
            Bill
            #786891
            Peter Cook 6
              @petercook6
              Rod, there is no suggestion that upgrading a non compliant Win 11 machine will stop you getting updates. Currently both machines update as they should. The interweb suggests that they will not get major feature upgrades, only security and bug fixes etc. However MS support feature upgrades for 2 years, so at worst I have security updates up to December 2026 which is beyond the 1 years paid for updates to Windows 10 currently on offer at $30/machine. Perhaps I will have to repeat the exercise in 18 months or so.
              David, I was not (and never will) explain how to do it. There is plenty of information out there should people wish to do  it – or not – as per their personal choice.
              I was merely reporting – to anyone on here who might be interested – that the Rufus based method does work. But for clarity; if you download Rufus and use it to build a bootable USB stick using a Windows 11 ISO, one of the options offered during the build process is to bypass the constraints. And it works.
              PS the Windows update page now says ” Windows update is committed to helping reduce carbon emissions” but clearly is committed to increasing electronic landfill!
