Hello Mr Foote:
The last article on constructing this locomotive was published in ME as you state above, 14th November 2014. Here is a searchable index so that you can ensure that you have all the relevant parts available. You should note that there is a typo in the 'year of publication' given in the index, it should read 2014, not as 2004. The volume issues and page numbers are however correct – so far as I can see.
I think that you will find that there is plenty of room between the frames for the crank-shaft bearings, cylinders, valve-gear etc., after-all you have 270mm (10 1/2" approx.) width to play with! Depending on your exact valve-gear layout you may have to either marginally resize the boiler or drop it slightly. But, as the boiler in 4" to the foot scale (7 1/4" gauge) is going to be around 10" diameter you have some leeway In this too. The reason for publication ceasing was not as given in the response above.
If you intend to tackle this model it may be useful for you to know that I have had a set of frames cut by Model Engineers Laser for 3 1/2" gauge, 2" to the foot. I am sure that if you contacted Malcolm he could use my drawings which he has on file (somewhere!) to cut you another set 'doubled-up' in 5mm thick material. There are two drawings, left and right frame, the sole difference being that the right-hand frame has holes pierced for the reversing stand and lever. You should note however, that my frames do not follow Cliff Almonds drawing exactly. I redrew the frames completely, in so far as I could, 'to scale', however the relationship of the crankshaft bearing cut-out and cylinder location points remains as Cliff Almonds drawing, tho' I suggest that you check that – you will have to design your own valve-gear & 'works' etc., anyway. In any event, from memory, there is not enough information on Cliff Almonds drawings to actually draw or indeed cut the frames 'exactly'. As you know, the outside profile has some quite complex merging curves and my recollection in that amongst other things the radii of many of these are missing from Mr Almond's drawings. You should also note that I have all the rivet-holes cut out as per 'works drawings'. Different batches of locomotives had slightly different lay-outs and underwent further modifications, especially as regards the side-tanks.
I dare-say that Malcolm at Model Engineers Laser could possibly send you the dxf file or similar for you to look-at if you are serious, then you could see if it would serve your needs and/or adapt it to your specific requirements perhaps??
Phil
Edited By Weary on 30/05/2019 21:57:39
