WILESCO BOILERS.
WILESCO BOILERS.
Home Forums Stationary engines WILESCO BOILERS.
  • #614419
    noel shelley
      @noelshelley55608
      I know that some would struggle to accept a Wilesco steam model as REAL model engineering BUt I have a wilesco boiler with a leak on the front plate, the mounting for the gauge glass is soldered into the front plate. It may have been caused by being run dry. There is no sign of the joint between the front plate and the barrel having run. They are not constructed with soft solder and I'm lead to believe that they are not SILVER SOLDERED some sort of half way house.Someone else has tried soft solder but they had not enough heat and have made a real mess. Any advice before I make a mess ? Yes I know I can get a new one for £50 but that would be to admit defeat !!!   Noel.
      Edited By noel shelley on 21/09/2022 20:45:34
      noel shelley
        @noelshelley55608
        #614421
        bernard towers
          @bernardtowers37738
          Noel could it be comsol or similar?
          #614448
          noel shelley
            @noelshelley55608
            Thanks Bernard, that was my thought, where would one get such material ? Noel.
            #614455
            Bazyle
              @bazyle
              Google it. I had thought being a lead based one it wouldn't be available but it seems to be from various suppliers. Just glancing at the Google synopsis there is some variation in the declared melting point that might need further investigation.
              #614460
                Reeves now do a solder with the same 305deg melting point as Comsol and Cup have their version at 296degrees
                #614487
                bernard towers
                  @bernardtowers37738
                  Noel , you’re going to the midlands show get it from cup alloys
                  #614501
                  kevin laxon
                    @kevinlaxon28008
                    Noel, I had a leak on a wilesco roller & like you it turned out to be a poor solder joint between the boiler & sight glass housing, nothing to suggest being run dry, it took very little heat to dismantle the parts so I felt it was just soft solder & used good old leaded solder to make the repair, its been no problems since & fire many times.
                    #614513
                    noel shelley
                      @noelshelley55608
                      Thanks to all who have replied. I have ordered 2' of comsol from one of our suppliers as the postage was less than £2 Thanks Kevin, you have confirmed what would be my way of doing it, ie heat it part it, clean and reflux then resolder. Don't forget to bring drill bits to the Midland Chaps. Noel.
                    Home Forums Stationary engines Topics
