Posted by Raphael Golez on 09/09/2021 06:11:28:
Hi Bill, thats an amazing shot, wish I could have the same shot. Can you explain how did you managed this shot…I mean the process, settings and how did you time this? Looks like a southern hawker.
Raphael, there is an awful lot of rejects in the "Deleted Items" folder; It's not something I could ever have achieved with film.
It's actually quite a heavy crop, so looks OK on here, but I'm sure wouldn't stand printing.
Camera is Olympus E-M1 Mk2 and the lens 40-150mm F2.8 + MC2.0 teleconverter, set at 100mm, so giving 200mm actual focal length.
The Olympus system is a half sized sensor, so EFL is 400mm in full frame terms.
exif says 1/1000 @ F8 iso 1000. It will have been electronic shutter set at 10 frames/second, and C/AF.
I think this is one where I was practicing using the Olympus EE-1 red dot sight.
It clips onto the hot shoe mount and provides a sort of head up display with a red circle and cross hairs.
This allows you to forget the viewfinder and rear screen, and compose with both eyes, sighting through the head up display. I've only used it on Olympus cameras, but I can't see any obvious reason it wouldn't function on other brands, as there is no electrical connection to the camera.
It was processed in DxO Optics PhotoLab 4 Elite, which features something called "Deep Prime" noise reduction, something similar to Topaz, but on Olympus raw images it seems to be slightly better; I can't comment on how they perform with other manufacturers raw files.
I'll have some some fairly basic editing, as I'm no expert, but will have used a simple mask on the dragonfly and applies a bit of micro-contrast, and probably a little bit of colour boost.
If you click on the photo, it should take to a Flickr album, where the rest of the exif is available.
Bill
