Brian, ten minutes is about what I would expect , most of my larger meths burners burn at a rate of one ml per minute, if you fill them more you don't get a proportionally longer burn time because as the whole unit heats up some of the fuel vapour is vented via the vent hole, sometimes lighting up.
You need a lamp with a good size flame. My small boilers are horizontal, and use either a trough like burner as in Mamod SE 2, or similar to yours(one tank), but with 3 wicks.
Ian S C
