In light of further comments, I may revise my previous posting
I'm wrong again.
I was envisaging a pillow block type of arrangement where one end of the shaft could be moved up and down by a screw mechanism to induce tilt, the movement being between outer race and housing, rather than outer and inner race.
But there would need to be a bearing of some sort where the screw mechanism is, so not as simple as I first thought.
However, you CAN apparently get sealed self-aligning bearings, so something learned anyway
Rob
