Posted by DMB on 10/03/2023 10:26:55:
Clive, agree on wretched gas meters. I'm also OK with ability to convert reading to KWH, but why should I have to? I think that all future gas meters due for renewal, should only be calibrated in KWH, to make life easier for all. I expect someone will say, ah yet but calorific value changes or some other silly excuse. Let the supply co. struggle with that one…
Bit of trivia, but Gas Suppliers have been required to charge for the energy their gas supplied when burnt, rather than the volume delivered, since the Gas Regulation Act (1920).
Gas was originally supplied for lighting, not warming the house or cooking, and it was a great improvement over tallow wicks, candles, and oil-lamps, even when burned in a plain mantel.
People valued gas for it's ability to burn with a bright yellow flame, not it's heat value. Hence gas meters measured volume, in cubic feet. Later, gas was used to heat water in bathrooms and kitchens, to warm homes with gas-fires, and as a source of industrial heat. Also, incandescent gas mantels had been developed: these produce a bright white light from being heated, and are poisoned by the chemicals in gas that produce the yellow flame so valued by early Victorians. Plus gaslight was being supplanted by electric light, which was cooler, brighter, and more convenient. As usual the small-c conservatives of the day resisted all change to the best of their ability, so it took over 25 years to make the switch from measuring volume to heat value.
When it finally happened there was a kerfuffle when gas bills charged 10d per therm rather than the good old 3s 11½d per thousand cubic feet everyone was used to, and obviously the old ways are the best.
Another amusing example of people objecting strongly to replacing an out-dated system they thought they understood, but didn't. Didn't matter the new waywas simpler and far more informative, because everyone hates change! Even me.
And here we are again, 57 years after metrication, UK gas bills are still confusing! And the change could have been made in 1920, because engineers and scientists understood therms and kwh long before then.
By the by, a US Therm and British Therm are both 100,000 British Thermal Units, except a British Therm is smaller, a mere 0.99976 US Therms. Something to do with National one-upmanship I expect, big countries need bigger Therms!
