Why is the world of model engineering still imperial?
Home Forums Beginners questions Why is the world of model engineering still imperial?
Viewing 25 posts - 1 through 25 (of 223 total)
  • #635880
    Paul McDonough
      @paulmcdonough43628
      Not trying to be antagonistic, honestly, just asking really, why is the world of model engineering still in imperial? we have been designing buildings in mm for over 40 years.
      I remember from my teens using BA threads and imperial threaded fittings from Stuart Turner but I wonder why we still seem to be working in this world?
      Says the bloke who has just had to buy a set of BA taps and dies! :0)
      Paul McDonough
        @paulmcdonough43628
        #635886
        Roderick Jenkins
          @roderickjenkins93242
          It's a good question.
          Off the top of my head I get think of 3 reasons:
          Most of the published designs are old or from the US
          The old machines that we repurpose for ME are imperial
          Most of us are old gits
          Rod
          #635887
          Perko7
            @perko7
            Apart from 5BA and 7BA hex-head bolts in exposed areas for cosmetic reasons, and 10BA round-head screws in some areas to replicate rivet heads, all other threads on my non-steam loco are metric.
            Steam loco currently under construction has 6BA for all cosmetic bolts, metric elsewhere. Have not progressed to boiler and cab yet so may need to revise this later.
            If only someone had the necessary financial resources to produce a range of metric hex-head steel bolts in the smaller sizes matching BA up to say 10BA. Smallest I have found locally (Australia) is M3 and only in Stainless Steel.
            #635888
            roy entwistle
              @royentwistle24699
              There's nothing wrong with imperial.
              Another old git
              Roy
              #635892
                Depends what you call the model engineering world, I've done several models form designs that originate in mainland Europe and they are metric and my map has europe as part of the world.
                More likely most commonly built designs are 40+ years old and have not been updated but there are a good few metric ones about now all my published ones are and a lot more that have not been published. All those Elmers kits that your supplier sells are based on designs from the US that are Donkeys years old so that is why your engine is in imperial but as the parts don't include fixings you could easily have substituted metric rather than blindly follow the drawings.
                Perko you can get small hex metric fixings, I use them all the time brass, steel and stainless M1.2 to M4
                Edited By JasonB on 03/03/2023 12:21:09
                #635893
                IanT
                  @iant
                  I'm not sure it is still Imperial Paul – most new machine tools (here in UK) are metric, as are much of the tooling used with them. I work in both metric and imperial in ways that make sense to me but maybe not to others.
                  All my machines are imperial. My CAD designs are in metric and I (mostly) use metric drawings. I have a mix of metric and imperial tooling. For my 'model' engineering, I mainly use BA screws and threading/tapping tools because I have models that were built with them and I still have ample stocks of both. For my 'engineering' work (jigs,tooling,accessories) I generally use metric fixings (M2 up) because they are inexpensive compared to imperial these days. When I'm working/repairing my machines, I use imperial/US screws because that's how they were made.
                  So it's complicated but mostly down to personal preference and habit. I generally think in feet, yards and miles for larger distances, millimetres for most things between 1000 and about 4mm – and 'thous' when I'm machining. A friend of mine uses imperial measures exclusively but 'decimal' imperial (not fractional) – which works very well for him. I do this myself sometimes – it's often easier to 'think' of 1/8" as 0.125" (or 125 thou) as a simple example.
                  I should add that BA is based on a metric system and still works extremely well (as do the ME 32/40 threads) for the kind of work that many do. Once you've got used to remembering that 1mm is (about) 40 thou – then things become much easier too.
                  IanT
                  Edited By IanT on 03/03/2023 12:21:47
                  #635894
                  not done it yet
                    @notdoneityet
                    Posted by Roderick Jenkins on 03/03/2023 12:02:58:
                    Rod
                    And most things were easily scaled down from feet and inches drawings to feet and inches models? Fairly obvious when most model engineers were still only using imperial machines?
                    #635895
                    Howard Lewis
                      @howardlewis46836
                      If a workshop was set up with Imperial machines and measuring equipment, having to calculate evry dimension from metric into Imperial is a PITA.
                      Many of the models that are still being made are to drawings that were produced way before 1971 and UK deciding to go metric.
                      Anyone restoring old machines (Unless continental ; machine tools, tractors, cars, motor cycles, locomotives, agriculktural equipment is likely to find that many, if not all the dimensions are Imperial d r
                      And they are only dimensions.
                      As long as there is enough material to fulfill the purpose, does it REALLY matter?
                      A 12 mm shaft and bearing will perform as well as a 1/2 " unless pushed to the absolute limit..
                      BUT, a model of a machine originall made and built with Imperial fasteners might look a bit strange with Metric fasteners. Especially to the fastidious.
                      And working on a machine with a mixture of threads / dimensions can be frustrating, to sayb the least. (The Bristol RE used a Gardner engine using Whitworth thread forms. But the bell housing was fixed to the engine using nine 3/8 BSF bolts and three 3/8 UNF nuts. And the rest of the chassi fixings were Unified.
                      The Leyland Leopard chassis was to Unified standards, but was powered by the 0600 or 0680 engines to Whitwirth standards.
                      Both were sources of frustration to fitters!
                      And for some purposes, Imperial may be better, such as 40 tpi Model Engineer threads.
                      And the Continent still uses Imperial threads . We call them BSP, they call them "gas" or "gaz"
                      #635896
                      Hopper
                        @hopper
                        Because fractions like 27/64ths are so much easier to use than big long numbers like 17.05mm. wink
                        #635900
                        JA
                          @ja
                          As said, almost all designs and available castings are old. Fixings are dominated by BA (OK, they are Metric but that is not relevant) because they are readily available.
                          If you want to spend some time take an old design (of anything) and try to convert it completely to Metric as a paper exercise. In theory good looking small metric nuts and screws are available in the UK. I have found two suppliers: One has a lead time of over a month and their nuts and screws look OK although they are stainless steel, the other imports from Germany and I have waited about a year for my small order which is yet to arrive (just to take a look ay their quality). Ordering from Germany was far quicker. As for Metric rivets, make your own, I have only found one supplier and the rivets are stainless steel.
                          This will change very slowly. It costs money to change and the market is declining (for fixings, castings, designs and major hardware).
                          There is nothing wrong with either Imperial or Metric. It is far better to be in the workshop than having a fake arguement.
                          JA
                          #635901
                          duncan webster 1
                            @duncanwebster1
                            Posted by not done it yet on 03/03/2023 12:23:04:
                            Rod
                            Dividing by 11 1/16 for 5" g locos is really easy. Using metric might encourage younger people, who simply don't understand imperial, and we wouldn't want that would we
                            #635910
                            Anonymous
                              Posted by Paul McDonough on 03/03/2023 11:50:26:
                              …why is the world of model engineering still in imperial?
                              Who cares! smile
                              I use metric and imperial, both for hobby and commercial machining as appropriate. But then again I'm making parts, not sitting in my armchair.
                              #635911
                              Andrew Tinsley
                                @andrewtinsley63637
                                I use any standards that are called for, be they metric, imperial or even older standards. It causes me no problem. The only downside is that you need extra kit. But again that isn't a problem for me as I repair old stuff that calls for just about any of the thread standards you could think of. So having lots of different tooling is a benefit.
                                Andrew.
                                #635912
                                  JA I also get my metric fixings direct from Germany, the same company GHW has a bit more in their range of metric rivits in several materials, usually 3-4 days DHL delivery
                                  Converting old designs to metric need not just be a paper exercise. I've done it many times right through to the metal bit and I don't just mean using 25.4 conversion and kidding yourself that a 6.35mm shaft is metric when we all know it's a 1/4" shaft expressed in metric. I change all stock to nominal sizes, ditto fixings including fine pitch metric in place of 32 and 40TPI and may well alter the physical shape of the "castings" to whole digit metric which just makes it so much easier when machining if you want to allow for a tool offset or work from a ctr line datum. There are also a couple of simple conversion ratios that can be used particularly if you want a larger or smaller version such as 1/16" = 1mm or 1/32" =1mm
                                  As to sticking with old imperial castings, I think my views on that have been covered well here in the past.
                                  <>Paul, if you want to try a metric wobbler after that imperial one have a look at this
                                  Edited By JasonB on 03/03/2023 13:27:53
                                  #635914
                                  Ady1
                                    @ady1
                                    I've had modern stuff via Lidl that's still got Imperial fixings
                                    The Chinese make stuff for the USA market and send rebadged ones to the EU
                                    If the USA switched then Imperial would go
                                    #635918
                                    Paul McDonough
                                      @paulmcdonough43628
                                      LOL, thank you for all of your replies, as an old git my self I am quite at home with either system and yes I had heard the BA threads were based on the metric system, i just wasn't sure that I should believe them or not!
                                      I often have to correct my self when i use expressions like , "oh you know about 2" quickly followed by "50mm"
                                      Old habits die hard and being able to half and half again etc is a nice feature of the imperial system.
                                      When measuring up for furniture etc I use which ever system gives the result closest to a whole number or easiest to remember!
                                      BTW I will try to remember that "1mm is (about) 40 thou". Thank you for that one.
                                      Edited By Paul McDonough on 03/03/2023 13:47:53
                                      Edited By Paul McDonough on 03/03/2023 13:48:26
                                      #635920
                                      Paul McDonough
                                        @paulmcdonough43628
                                        Thank you for the suggestion JasonB, "<>Paul, if you want to try a metric wobbler after that imperial one have a look at this" that looks nice but i have a H10 lined up for my next project,
                                        I just hope i haven't bitten off more than I can chew.
                                        #635922
                                        UncouthJ
                                          @uncouthj
                                          Metric is great when dealing with whole numbers, but imperial is inherently geared up to provide fractional measures to get you in the ball park and dial in a dimension. It's 6 and half a dozen when using a DRO, but for anything that wants measuring to the mic gauge, I'll take imperial every time given the option. Additionally, and this could be an autistic brain thing rather than a rule, but I find there's patterns to imperial measurements that I just don't feel in metric…
                                          J
                                          #635928
                                          Paul McDonough
                                            @paulmcdonough43628
                                            Posted by UncouthJ on 03/03/2023 14:11:24:
                                            J
                                            I agree
                                            #635930
                                            Jim Guthrie
                                              @jimguthrie82658
                                              I suspect that the preference for Metric or Imperial might depend on what machinery you have. My outside workshop has an Imperial ML10 bought new in the early 1970s and an Imperial Centec 2A Mill which is probably twenty years older than the lathe. Everything in the workshop is Imperial and the only conversion I make in there is fractional to decimal to use the lathe or mill handwheel readings.
                                              My inside workshop is Metric with a relatively new Cowells and a Sieg KX1, so everything done in this workshop is metric with metric measuring tools. So I have to switch from Imperial thinking to Metric thinking and vice versa when I move between the workshops. smiley
                                              I have no real problem with switching between the two. At my school in the 1950s Physics was taught using the cm/gm system and Applied Mechanics using ft/lb. smiley
                                              Jim.
                                              Edited By Jim Guthrie on 03/03/2023 14:40:38
                                              Edited By Jim Guthrie on 03/03/2023 14:41:25
                                              #635934
                                                Imperial lathe and mill for me so may not apply in some cases. Though with a DRO on the manual mill I seldom actually look at the handwheel dials. lathe is easy enough to convert with the digi callipers or a calculator
                                                CNC mill will just cut whatever it's told in my case metric
                                                #635937
                                                duncan webster 1
                                                  @duncanwebster1
                                                  Just to keep the fractions brigade happy I'm thinking of making a range of micrometers which read out in 1024 ths. This is 2 raised to power 10. You can't have it both ways, if you want fractions, you're cheating if you suddenly go to decimal inches when you need some precision. This argument is futile anyway, no young person understands Imperial, even in the USA science is conducted in SI, and I believe the space programme is in SI after an unfortunate mis understanding.
                                                  I'm old, I have an imperial milling machine with DRO, I habitually use it in metric, it's easier
                                                  #635939
                                                  Martin Kyte
                                                    @martinkyte99762
                                                    OK, here is my twopence worth.
                                                    Generally the prototype of the model was designed in imperial so scaling to imperial is easier.
                                                    BA fasteners were designed for models and instruments with suitable size heads to represent whitworth fasteners.
                                                    Part of the enjoyment for me at least is walking a similar road to the machinists and designers who worked on the prototype and using the same measurement system helps with that.
                                                    I have a clock design which I shall build at some stage and it’s a conversion to metric design and looks a complete mess in terms of dimensioning.
                                                    All that said I don’t have any issue with stuff designed in metric from the get go.
                                                    Regards Martin
                                                    Edited By Martin Kyte on 03/03/2023 15:14:02
                                                    #635944
                                                    Paul McDonough
                                                      @paulmcdonough43628
                                                      Posted by Martin Kyte on 03/03/2023 15:12:52:
                                                      I can relate to this the other way around, a popular scale for model ships is 1/2" to the foot, a person in scale is 2 3/4" to 3" tall and 120' tugs neatly end up 60" long!
