On
13 November 2023 at 07:00 JasonB Said:
………….Or like latest posts that is now fixed so you won’t get all the comments asking for that
It is a little better but painfully slow, sometimes I loose the will to live and give up with it. Then move onto something else that interests me and works at reasonable speeds.
I find that selecting a posting and then doing something else while it loads is much less frustrating.
Except that I’d suggest that Latest Replies isn’t fixed; it exists in a more useable format certainly, and is more informative, with more options for topic navigation.
The following is something I’ve discussed before, with timed screenshots, so I’ll not repeat them here.
”Latest Replies” doesn’t seem to work (currently) the way some people think; The “Blue Button” operates differently in this new implementation to the original temporary offering.
When you refresh a page, whilst viewing something on the forum, a new Latest Replies list is generated, and displayed below whatever topic you were viewing.
It’s in a similar format to “Forums”, but date ordered and works well, depending on where you click; I’m ignoring the right hand Latest replies banner/ list for the time being.
The Latest Replies Blue Button, does not seem to re-generate a new list; It just auto scrolls down the page to the list you already had open, which I think is why it appears to work quickly.
This is easy to demonstrate, leave a topic open in a tab, spend a couple of hours in the workshop, re-press Blue Latest Replies Blue Button Button, without doing anything to cause a screen refresh; immediate response down to the already displayed list, but it’s two hours out of date.
Refresh the screen, by whatever means, a long delay, 30 seconds currently, and a re-compiled current Latest Replies list, in time order, appears below what you were viewing.
Anything that forces a screen refresh, back button, edit, comment, Control F5, select different topic/post etc, seems to generate a new Latest Replies list when logged on, along with the inherent delay.
N.B. Log out of forum, Latest Replies list is not always current, and may not update for ages; navigating around the forum is fast, perhaps because the list is not updating with each screen refresh.
Log back in, wade through treacle with every screen refresh, whilst waiting for the list to re-compile.
I may be barking up the wrong tree entirely, but I’ve tried to explain this several times, with timed screenshots, but no replies from Admin/Developers to this potential bottleneck, which only seems to occur when a user is logged in.
I can imagine that when several users are logged in, and accessing the forum simultaneously, re-generating the list for each of their screen refreshes might be a higher load on the server.
Currently the time delay for a screen refresh, when viewing forums with Latest Replies, is about 30 seconds; other occasions have been almost a full minute.
If we had a display of the number of logged in users, that might give further indication.
It only seems to be when Latest Replies is implemented for a logged in user, that the refresh rate is slow.
The rest of the site is speedy enough whether logged in or out.
Bill
