Posted by David Atkins on 13/11/2010 21:24:08:
Anyone ever wondered what today’s model engineering scene would be like without cheap Chinese tooling ?
I suspect it would be much smaller as many of us would only be able to look at some lucky fellows expensive 30 year old British built lathe and wish we could afford one.
We are likely to get told off if we do this,
but yes I have thought about it, and there are several possibilities: Firstly, perhaps not all of the firms that used to make smaller-scale machine tools would have gone out of business, which might have forced the remaining one’s prices down a bit… secondly, and probably more realistically, it would have forced the price of comparatively rare non-Chinese machines to be rather higher than it already is – simply because of scarcity value.
So even though I don’t personally use Chinese machine tools at home, I’m still very grateful that they exist, because it would almost inevitably have put the prices of the UK stuff I do use out of my reach if they didn’t. Some of these machines are relatively expensive anyway – the price of Senior mills still holds up pretty well, and it’s still difficult to pick up even an old UK-made lathe that’s any good as it stands for less than about £600. And if you buy this stuff, you will probably still have to do as much work to it as you might to some new Chinese machine tools – you still have wear problems to deal with, after all. And on that basis, you are looking at a similar prospect in both cases – you’ve bought a set of castings, and you are fixing them up to a standard you’re happy with.
In my case it was a matter of circumstance that it worked out like this; I could just as easily have bought Chinese for most of what I’ve got, I think, and almost certainly have got perfectly acceptable (to me) results from it, as generally it’s not the tools that cause the indifferent results, is it?
