Why are flywheel keys square?
Home Forums I/C Engines Why are flywheel keys square?
  • #2337
    John Wood1
      @johnwood1
      There must be a reason!
      John Wood1
        @johnwood1
        I am currently building the Redwing engine and have got to the flywheels. The keyway has to be broached but I don't have a proper broach and therefore have to use a square ended tool and 'plane' the metal away. The problem is the casting is so hard thet I struggle to take any metal off at all. I have made a cast iron plug to fit snugly into the centre and drilled through at the intersection, this removes most of the metal and I have now managed to get a decent square groove,
        It occured to me that if one used a round key then all this fuss would be avoided – wouldn't it? I know one would have to use a round nosed cutter to mill the corresponding groove in the crankshaft but I reckon that's easier than broaching.
        I bet there is something I have not realised so would someone please enlighten me?
        Thanks, John
        #89657
        John Stevenson 1
          @johnstevenson1
          Because there is no sudden change in section like you get when you come across the wall of a key, the round type is gradual and in time will roll over and extend the 1/2 hole.
          John S.
          #89658
          Engine Builder
            @enginebuilder
            Hi John, This a method I use for my flywheels.
            Flwheel is held by a collet with dummy key.
            Edited By David Clark 1 on 24/04/2012 21:01:30
            #89659
              They must be very hard castings if you can't plane them after drilling. I've used the planing method for keyways 3/16" wide and 1" long in steel without drilling first, just 1 or 2 thou at a time and its soon done see this
              Though I have now bought a set of miniature broaches from the states at a very reasonable price its a minutes work to press them through, don't think I will be going back to planing.
              One of the reasons for a square hole is that the gib headed key can have a slight taper in its height so it tightens up as pushed in, you won't do that easily with a round hole.
              J
              #89660
              Russell Eberhardt
                @russelleberhardt48058
                John S is right of course, however I have used round keys with a bit of locktite to overcome the tendency to roll and never had a problem. If you can drill both the wheel and the axle with it assembled you can get a good fit easily.
                Russell.
                #89673
                Sub Mandrel
                  @submandrel
                  For small bores (say 1/4" to 5/32&quot I use a 'top hat' shaped filing guide with a slot in it and a square file.
                  Russell Eberhardt
                    Posted by Stub Mandrel on 24/04/2012 20:20:33:
                    For small bores (say 1/4" to 5/32" I use a 'top hat' shaped filing guide with a slot in it and a square file.
                    That must be a tiny file. What size key do you use on a 5/32 shaft!
                    Russell.
                    #89749
                    russell
                      @russell
                      very neat flywheel fitting (and engine).wink But some future engine restorer is going to have a b…..r of a time removing them!
                      russ
                      #89874
                      Sub Mandrel
                        @submandrel
                        well perhaps I meant 5/16"
                        John Wood1
                          @johnwood1
                          Many thanks for the posts which have helped me get my head around the subject. Also thanks for the other ideas, all useful info.
                          Cheers John
                        Home Forums I/C Engines Topics
