This is my understanding:
A single phase motor produces zero torque twice every AC cycle of the mains waveform, when that crosses zero volts. So there will be a deep torque ripple of 2 x mains frequency.
Compare that to a 3 phase motor; As each phase AC waveform goes "over top dead centre" and torque from that winding starts falling, the next phase – 120° behind it – is approaching "top dead centre", so its torque is increasing, and so-on; So a 3 phase motor will produce torque throughout each rotation and have only a very shallow torque ripple, which will be 3 x the frequency of a single phase motor.
So a 3 phase motor will have much higher torque, delivered much more smoothly.
You can think of this as a being similar to single cylinder 'thumper' internal combustion engine compared to a 3 cylinder engine: the more cylinders, the smoother the torque delivery.
Not being a machinist, I don't know if the torque ripple from a single phase motor is likely to cause more chatter etc. at the cutting bit, compared to a 3 phase motor ?
As an aside, I wonder if the addition of a flywheel onto a single phase motor would help? It would smooth out the torque ripple a bit and provide a more gentle slow start, though not a quick stop of course.
Edited By John Doe 2 on 21/01/2023 13:09:03
