Who stole my wallpaper paste ???
Home Forums The Tea Room Who stole my wallpaper paste ???
  • #775614
    Speedy Builder5
      @speedybuilder5
      I mix up a small pot of cold water paste and paste up some (Legitimate) posters around our tiny village and put the lid onto the pot – we don’t use the internet.  Perhaps a week later, I paste up a couple more posters.
      About 3 weeks later, I need some more paste, but SOMEONE has entered my shed, cracked the combination of my safe and stolen all the paste and this is the cunning bit, they replace the paste with water.
      Now how have they done that ?
      Confused BOB who has lost 10p worth of paste.
      larry phelan 1
        @larryphelan1
        Sounds like a case for the Village Bobby !
        If you get a trace of it, you need to stick with it, just dont get too hung up about it.
        I suppose you could try putting up a few posters asking for information ?, but then, you would need past for that, so that,s a no-no.
        #775635
          That’ll be the village witch, burn her!
          Carefull if you drop a poster, we don’t want any more paste side down
          #775680
          V8Eng
            @v8eng
            The Shed Elves up to mischief again!
            #775704
            Bazyle
              @bazyle
              Engineering solution – drawing pins.
              #775705
              Plasma
                @plasma
                Curious that, about six months ago I saved about a pint of paste in a sealed plastic container (i kid myself it was in case i needed to paste any edges down but it’s probably because age related retention is taking hold).
                I saw it this very afternoon on a shelf and it too had changed into clear runny water!
                Not sure what to blame it on, not even Musk or Trump have made threats to our decorating materials  (yet).
                Mick
                #775708
                  I suppose when you mix it up the flakes are saturated but in suspension but after time they possibly dissolve and that may make you think you just have water but it will still contain the dissolved contents. Drink it and see!
                  #775711
                    Frost. That’s what does it. Repeated freezing cycles separate the water from the starch and the gel gets broken down.
                    #775713
                    duncan webster 1
                      @duncanwebster1
                      Paste is noticeably thinner after a week or so without frost. Be warned, emulsion paint is completely wrecked by frost. Proper alkyd paint is unharmed apart from being thicker when it’s cold, recovers when warm.
                      #775716
                      V8Eng
                        @v8eng
                        Somebody could come to a sticky end that way😉
                        Sorry the temptation was too great!
                        #775720
                        Andy Stopford
                          @andystopford50521
                          The mixed paste is a colloid:
                          https://en.wikipedia.org/wiki/Colloid
                          Over time, it turns into a solution and the colloidal gel properties are lost.
                          #775726
                          Martin Kyte
                            @martinkyte99762
                            Has to be that the long chains of the starch are being broken up by the water.
                            #775730
                            Martin Kyte
                              @martinkyte99762
                              Essentially hydrolysed into sugars
                              #775735
                              Speedy Builder5
                                @speedybuilder5
                                Martin K,
                                Ah sugar – If I left it open, would natural yeasts get into it and then turn into ALCOHOL ????
                                #775743
                                  So now we seem to have solvited that question
                                  Who can tell my why premixed paste can stay like it should for far longer?
                                  I’ve used the premixed for many years now as it is consistant and you can just spread it with a paint roller in a fraction of the time. Also what a lot of the decent paper supplers say to use. Also suitable for the paste the wall papers.
                                  #775754
                                  Andy Stopford
                                    @andystopford50521
                                    I would guess the manufacturers use some additive to inhibit the phase change of the starch from suspended solid particles to a solution. This might not be possible with the mix-it-yourself version because it needs some special mixing process. They might even use something different from starch as the solid part.
                                    #775756
                                    Martin Kyte
                                      @martinkyte99762
                                      At a guess they probably alter the pH
                                      #776071
                                      Hugh Stewart-Smith 1
                                        @hughstewart-smith1
                                        Drink it and end up looking somewhat………….. pasty.
                                        Mm, sorry about that one!
                                        Hugh
                                        #776131
                                        Nigel Graham 2
                                          @nigelgraham2
                                          Ah – is the separation of olive-oil in the bottle in a fairly cold cupboard, related to that affecting paste?
                                          It breaks into a suspension of “bits” in the clear fluid.
                                          #776134
                                          Alan Charleston
                                            @alancharleston78882
                                            Hi,
                                            The active ingredient in wallpaper paste is usually methyl cellulose. It dissolves in water at low temperatures and turns into a gel when heated.
                                            https://www.sciencedirect.com/science/article/abs/pii/S0079670020301179
                                            This is reversible so if your paste gets too cold it will become a solution. Try heating the liquid you were left with and see if it turns back into a paste.
                                            Alan C.
