Having built Sophie I would not say it is a beginners project per say, it does not help that the instructions are in German. The column should be turned in one piece and is relatively easy to do.
With regard to the flywheel I do not think it would look right at 80 mm.
Although many parts are all ready cnc'd a mill/drill does make life easier. It is a nice looking model when completed.
If you are not sure of your capabilities make a start on some of the simpler parts, as you get to the more complex parts just put it on one side and make something else till you get the confidence.
I made a wobbler from a casting kit and found that harder to get ones head around than Sophie, fortunately having put it aside for a few months, when I came back to it, everything just dropped into place and the completed engine runs very well.
There are a lot of very fiddly parts in Sophie and small screws,nuts and bolts (2mm and 2.5 mm)
Suggest you keep all parts/materials in one box and the finished parts in another. I have spent hours looking for dropped nuts and boltsÂÂ
Go for it, it will give you the incentive to learn what you need.
ÂÂ
ÂÂ
Edited By Howi on 20/07/2016 17:12:10
