Can’t help with someone to move it, but they are not nice to shift if sat on the floor. Hauled mine with a flatbed trailer, but it was a pain.
Horrible awkward thing to move about, and surprisingly heavy, rollers are not really an option, you need to crane them ideally. Also make sure you empty the hydraulic tank before transporting, otherwise you will end up with oil everywhere you don't want it to be.
If you do sling it, only use the prescribed lifting points, mine has eyes screwed into the top, don’t be tempted to put straps around the bed, as it’s just sat on the ways.
The height of the lifting points makes it awkward to use something like an engine crane. Mine was craned onto the trailer and i used a block and tackle at my end to get it off.
Good luck with the move.
