I am making some half-shaft axles for a tricycle which are of nominal 12mm diameter.
First set I made were from plain old 12mm milt steel and I did not expect the round bar to be a precision piece of rolled steel and fit perfectly through the 28x12x8mm deep groove ball bearings of the outer axle-tube. I was not disappointed in this belief and no, the bearings would not slip along the length of the axle shaft.
What I did to make them work quite well was to mount them in my lathe chuck and a tailstock centre and run the lathe up while looping a piece of oiled emery cloth around the bar and traversing the entire length back and forth with frequent stops to check on progress with a bearing.
Soon enough the "slip-fit" I was looking for was achieved. ![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
I have a concern that "mild-steel" just won't cut the mustard for this application and so I am replacing the mild-steel with Silver steel equivalents.
Now, I had expected this much more expensive bar stock to be produced, rolled & polished to a much tighter tolerance to 12mm than it appears to be, seeing as it is commonly used in gearboxes as layshafts. But No! ![sad sad](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
The bar is marked "Precision 12mm BS1407" which I believe is meant to be within tolerance by 0.00025" So I guess I got a piece that is on the high side and not the low side Ha! Ha!
Now Silver steel is a darned sight tougher than mild steel and the same trick is taking FOREVER.
Is there a better way of bringing such stock down so marginally that it fits the precision manufactured race of a bearing? It seems to me that taking a tool to it is overkill and will ruin the steel because it probably isn't even 0.00015" oversize. Is effectively "polishing it down" to size with emery cloth the only real way to do this? If it is the only way so be it, I just wondered if there was a better/easier and more "approved" way.
TIA.
Dan.
