Whistle making, particularly the valve
Home Forums Help and Assistance! (Offered or Wanted) Whistle making, particularly the valve
  • #222802
    Andydextrous
      @andydextrous
      Hi, does anyone know where I might find a drawing/design, for a whistle that incorporates a valve in the base below the bell. It is the design of the valve that I don't understand – the sort that has a pin operated by a lever. Commercial items aren't to the right scale for what I want. Cheers, Andy
      Andydextrous
        @andydextrous
        #222811
          Most are just like a car engine valve – tapered seat and a matching angle on teh head of teh valve, valve stem passes up through teh whistle body where it can be pressed down. What scale are you looking for?
          #222818
          Andydextrous
            @andydextrous
            Thanks, that makes sense except that the valve is horizontal. There must be some complicated chambers to get the inlet and the outlet vertical. 4 inch scale is too small and 6 inch slightly too big.
            #222824
            MichaelR
              @michaelr
              As Jason says, just like a car engine valve, hope this helps
              Edited By MichaelR on 27/01/2016 15:18:00
              #222829
                Michael's drawing is what you need not unlike a stopcock where the water pressure keeps the valve on its seat. I was thinking of a vertical one
                Worth looking about a bit as like the engines whistles came in different sizes so you may find a 6" scale one for a tractor is smaller than one for a 6" road loco.
                #222832
                Andydextrous
                  @andydextrous
                  Thanks. I know what I need to achieve now. I couldn’t find anything through Google.
