Posted by ALAN HEATH on 28/07/2020 09:11:50:
Thanks to everybody for your advice, being a total novice I will take more care in the metal I purchase, and have another go.
I wasted several months struggling to turn various bits of scrap and DIY store metal I'd collected randomly. Eventually, I got hold of some EN1A (one of mild-steels), and was amazed how well it cut. I was unlucky because all my scrap metal was horrible. I'd assumed a metal-lathe would happily cut any metal it was given: not so – many metals don't machine well. For example:
- Aluminium alloys intended to be extruded into window frames and the like are too soft and sticky to machine well. Avoid!
- Ordinary mild-steel (EN3) can be machined, but tears and can be difficult to get a good finish. EN1A, and – best of all EN1A-Pb (leaded steel) – are specifically formulated to machine well. Buy some!
- Hardened steels may be harder than the cutter. Some machine well with Carbide and most can be softened by heating them to red-heat and allowing them to cool slowly. An old-time recommendation was to put hard metal in a bright coal-fire and leave overnight to cool down as the fire burned out naturally. The type of hardened steel makes a difference: High Speed Steels are designed to resist heat softening, and may require a long high temperature soak to completely soften.
- Alloy steels are all over the shop. Some machine well, many are pigs. Modern seat-belt restraints are made from a Boron Steel harder and tougher than the 'Jaws of Life' used by the fire brigade to cut people from wrecks.
- Most Brasses machine well, but some are better than others.
- Bronze varies between good and bad.
- Cast-iron varies between excellent and horrible. All cast-iron is liable to have a very hard outer skin but cheap cast-iron can be full of slag and other horrors. Don't be surprised if a sash-weight is complete carp.
Bottom line on metals is they're engineered for a purpose, often not suitable for home workshops. Nowadays, I prefer to buy metal where machinablilty is mentioned positively in the description. Words like 'free-cutting'. If you have a local metal supplier, tell the man you want to machine it.
With experience it gets easier to cope with random scrap. I recommend beginners avoid unknown metals, because they can't tell if the problem is the operator, the machine, the cutter, or the material. Best to eliminate the material as a problem. In practice, I find scrap more trouble than it's worth.
Some lucky chaps have no scrap problems. I think it's down to were they live! In a manufacturing area suitable off-cuts are likely. Out in the sticks, probably not. The easy answer is to buy known materials.
