Hey Everyone,
thank you so so much for the responses I'll see if I can answer them all below:
Posted by John Haine on 18/11/2021 07:10:26:
Do you mean jobbing, or just cutting?
John Haine
what I meant was gear cutting
Idealy using a diving head and a rotary table.
Posted by JasonB on 18/11/2021 07:14:45:
I suspect you mean gear cutting as to do hobbing properly you really need a gear hobber, it can be approximated with home made tools but you would also need a lathe to do that.
An idea of the size (diameter and tooth size) of the gears as well as what material you want to make them from would give members a better idea of what machine to suggest.
You will almost certainly need some form or rotary table or dividing head to increment the blank around 1 tooth at a time so allow 250-300 euro for that. And easily the same again for some other basic tooling to go with the mill such as an arbor to hold the gear cutter, the cutters themselves, measuring tools to set the job up, etc.
The 1500 euros was for the MILL only I did kind of realise that the tooling and rotary table would be additional on top of that
With regards to size, they will be for small mechanical follies ( 5-10cm radius more or less) I'll be making to pass the time mainly.
Posted by Mike Hurley on 18/11/2021 10:13:34:
Welcome to the forum.
My recommendation is to look at this the other way around. If you haven't already done so, first get a copy of the Workshop Practice series book ' Gears and gear cutting '. It will cost less than a tenner from on line sources and will tell you what type of kit you need and how to use it. This may save you making an expensive mistake and buying equipment that is not fit for purpose.
Are you intending to make gears for a specific purpose?
Edited By Mike Hurley on 18/11/2021 10:16:49
I've allready got that book and had a read through I'm kind of theoretically aware of the gear making process I'm aware I need at least a mini mill of some time ( or a second hand full sizes mill, if I could fit it in the office…) My question was more around which one of the MANY mini mills should I purchase? are there any things I should be looking out for? Are some better than others? I've kind of realised that MOST appear to be "sieg" chinese mill's except Warco from what I can see.. but there are SO many different permutations… Some come with DRO ( do I NEED this?), some with auto feed vs manual feed? I'm just a bit lost in all honesty…
Posted by Howard Lewis on 18/11/2021 16:25:58:
Welcome!
If you are going in for gear manufacture, do buy Ivan law's book on "Gears and Gear Cutting" No.17 in the "Workshop Practice Series", as Mike Hurley has already recommended.
You will find it a great help. Study it well before starting to cut metal.
If need be make your mistakes on some trial pieces, to gain experience, before embarking on the final product,
It may help to bear in mind that gear cutters are numbered in the reverse order between Imperial (DP ) gears and Metric (Module ) gears.
You are also going to need a Dividing Head or Rotary Table, (With Tailstock ) and a 4 jaw chuck to hold the mandrels on which the gear blank will be mounted for machining.., The mini lathe will come into its own to make the mandrels on which to mount the gear blank
I prefer using Division Plates on a Rotary Table, to calculating the angular divisions and setting them on the vernier scale.
Since gear cutting involves a heavy cut, although at a very slow feed rate, you will need the Tailstock to support the mandrel on which the gear blank is mounted.
This also implies that the milling machine needs to be fairly substantial and rigid, if your gears are going to be made from steel. You can do small work on a large machine, but not so easily the other way round.
A larger, heavy machine will be more rigid, so an aid to quality, so buy a little larger than you initially anticipate
New machines will be Metric, so you will need a calculator to make the settings for Imperial gears…
If you do not have it already, you will need measuring equipment to measure diameters, and to ensure that the work is held concentric in the chuck.
thanks for this info Howard!!!! with regards to
Do you have any recommendations on what I need? I assume a micrometer, a dial indicator of some type anything else to start off?
1/2
Edited By Christopher Churchill on 18/11/2021 18:59:09
