Which steel for studs?
Home Forums Materials Which steel for studs?
Viewing 8 posts - 26 through 33 (of 33 total)
  • #764277
    Mark Rand
      @markrand96270
      Just a small point:-
      DO NOT USE EN1A!!!
      Sorry to shout, but it rusts as soon as you look at it indoors. On a tractor it will be a mess within the week outdoors, if it isn’t completely sealed. The leaded version is worse, but the re-sulfurized version is also prone to corrosion.
      EN8, unhardened is good for most uses. EN16T is better if higher strength is needed.
      bernard towers
        @bernardtowers37738
        Sorry but I use stacks of EN1A and dont have any rust problems except when people handle things at exhibitions and by the time I get things home they have rusty fingerprints on them. suggest its in your hand secretions. I do have a friend who has the same problem and I dont let him touch my tools!!!
        #764499
        Mark Rand
          @markrand96270
          Not finger secretions in my case, just storage of parts in the workshop and occasionally, outdoors. Compared with other steel alloys that I use, it’s terrible for corrosion.
          If it rusts within hours of some people touching it, how is it going to handle being used on a tractor? 🙂
          #777806
          Chris Trice
            @christrice43267
            Instinctively, I’d try to source a long suspension high tensile bolt from something like a Jaguar or a truck, cut to length and thread cut the ends appropriately. I can’t see many materials improving on the strength of that.
            #777829
            bernard towers
              @bernardtowers37738
              I personally dont think that using a converted HT bolt is a good idea as they machine badly which is why the originals are rolled in the first place, much better to use a machining friendly steel like the ones mentioned earlier ie EN8M or EN16 or if you can get hold of it USACUT55
              #777834
              Charles Lamont
                @charleslamont71117
                I often use HT bolts as a source of HT bar when I only need a bit and specification is not critical. I find a good quality cap-head best. I can usually machine them to a good finish without much trouble. The material is similar to EN24T.
                #777838
                howardb
                  @howardb
                  Just use EN8 it’s better than EN1A by a country mile for tensile strength of bolts, studs. and anything you need to be stronger than a DIY shop gutter bolt.
                  #778022
                  duncan webster 1
                    @duncanwebster1
                    Rolled threads are cheaper, but more importantly stronger than cut.
                  Home Forums Materials Topics
