I need some steel for a 35mm pulley shaft (and also a 20mm one). The 35mm shaft will support a load of around 25kg, rotating at around 40rpm. Proably around 100cm long. I am going to use pillow block bearings. What steel should I get? I was advised to get precision ground mild steel for this shaft.
Metal Supermarkets have 'engineering steel' precision ground bar, EN8, EN 16 and EN24. Also 4130 and 4140 (just round bar).
Also 'bright steel' EN3A. EN3A (leaded), EN3B, EN8,EN24, EN16, EN19.
I am confused, which one would be best?The 20mm I will need to machine, the 35mm shaft I possibly may need to, I have a mini-mill.
David
