Looking for advice on which slideway oil for my newly acquired WM250 lathe & WM16 Mill – would like to use the same oil for both machines, slides and general lubrication. Should I get 68 or 32 – is it only the viscosity that's different ? or should I use something different altogether ? Thanks in advance
ISO 68 Slideway oil for slideways. ISO 32 Hydraulic oil for lubrication. It's not just the viscosity that matters, slideway oil has a cling factor to keep it on the slideways, even the vertical ones.
