Which Razor saw?
Which Razor saw?
Home Forums Workshop Tools and Tooling Which Razor saw?
  • #158287
    Stevo
      @stevo
      Hi All…
      Appreciate that this is steering towards woodwork (?) but what do you recommend?
      I am after a GOOD set, nice and precision for Balsa, soft and the odd bit of hardwood.
      I look at it as an investment.
      Steve
      Stevo
        @stevo
        #158292
        Clive Hartland
          @clivehartland94829
          I bought a set with 2 saw blades and a handle for £8.50, I think Exacto. These are very fine blades so would be suitable for balsa.
          #158294
          Chris Trice
            @christrice43267
            The choice is so wide, the question almost has no meaning since they are all pretty much the same. It’s like asking what is the best hacksaw. You generally get what you pay for. Exacto do razor saws but the same saws are available under a multitude of brand names. I have a set I bought from EMA and these have replaceable blades but your local model shop which deals with radio controlled aircraft or model railways will have something suitable.
            #158295
              Ive always used the X-acto (no E and a hyphen) and had no problems with them. Though for larger bits look at some of the fine toothed Japanese saws these have blades down to around 0.4mm think and the way the teeth are cut there is minimal set to make the kerf wider than the actual blade.
              J
              Edited By JasonB on 20/07/2014 12:39:19
              #158299
                Steve,
                It's probably bigger than you had in mind, but I would highly recommend the Topman Z saw, and also the Sawing Guide that they sell.
                It's a modern version of the classic Japanese pull-saw, and the performance is amazing.
                They may do something smaller, I haven't checked.
                Edit: Topman website unfortunately has little technical content.
                Edited By Michael Gilligan on 20/07/2014 12:16:11
                #158301
                  Update: Here is the dedicated Z-Saw website
                  … definitely worth a look.
                  P.S. For the sake of TradeMark pedantry, I should have written TopMan.
                  #158303
                    Yes the 265 is probably a bit big, I have two of them smiley
                    For fine work then one of teh Dozuki type saws which have a back to them like a tennon saw would be better and if you get one with the "woodpecker" tip you can also start a cut mid panel, something like this would do
                    #160542
                    Vic
                      @vic
                      I've got this one, well pleased with it. Axminster also sell the Japanese ones as well.
                      http://www.axminster.co.uk/victor-razor-saw
                      #160543
                      Stevo
                        @stevo
                        Thanks Vic…
                        I bought a Japanese one while I was at Axminster.
                        great they are too!!!
                        #160558
                        Ed Duffner
                          @edduffner79357
                          Steve,
                          If you need to be really precise for small work I bought some of these blades a while back from Hannants. They'd be ok for balsa.
                          Ed.
                          #160562
                          Stevo
                            @stevo
                            Blimey they are fine at 5 thou…
                            good call!
                            #160564
                              Ed,
                              That's clever stuff !!
                              … am I right in assuming that there is no "set" on the teeth ?
