How fortunate Billy is to be setting up a new workshop with plenty of space! However, every silver lining comes with a cloud, in this case discovering that choosing a lathe can get complicated. Especially when it turns out you need a milling machine as well!
There are several considerations, and I would advise newcomers to start by collecting their ideas first. Write a list. Advice on the forum is good but beware you ask the right questions – what matters to Billy may not matter to me and vice versa. Like Billy suddenly mentioning he has trouble with weights.
Key things to clarify before parting with money:
- What are you going to use the lathe for? (Clocks or locomotive Axles?)
- Most important, what are your constraints?
- Budget, including costs of stand, tooling, accessories, electrics, delivery, installation and materials. (Installation might involve paying a professional team to move a heavy lathe into a cellar, or buying an engine crane, or perhaps you can do it for free.)
- Your experience and ability to cope. (Newcomers are advised to keep it simple.)
- Space
- Access to that space. (2 ton lathe in the loft; live 5 miles down a muddy lane; steps? )
- Power (Shed at the end of a garden; 3-phase; > 13A etc.)
- Noise and other impacts on your domestic situation
- Your feelings buying new vs second-hand or Western vs Far Eastern and how much those feelings matter to you. Be aware when taking advice that feelings and logic are not the same thing.
- Tooling: for example, if you particularly want to use carbide inserts a modern lathe is a better bet simply because they tend to spin faster. On the other hand, older lathes may come with hard to find accessories, such as a taper turning attachment. Do you have any special tool requirements?
Normally I would advise buying the biggest lathe that can be accommodated. Partly because bigger lathes handle bigger work, partly because interests expand to fit the lathe, but mostly – in my case – because having more room makes work easier to set up. Generally a big lathe can handle small work, but a small lathe cannot handle big work, and you end up pushing the thing to it's limits. In Billy's case, he particularly mentions weight as a problem. That might mean chuck weight is his showstopper: a 100mm diameter chuck weighs about 3kg, 120mm about 5kg and 160mm about 10kg. There may be other issues with big lathes; they take up space, you have to stand at them, and they're comparatively hot and noisy.
Last on my list is Make and Model Number. With older kit condition matters far more than brand. With new kit, warm feelings provided by Make and Model number may be misplaced. It's not obvious these days who made the lathe and there can be significant variation between similar models. In the UK, hobby lathes are bought from badge distributors, not manufacturers. Distributors can and do change supplier. You're far better off looking at what they have on offer and deciding who has the better reputation for support. That can vary over time. Personally I've had good results from Warco and ArcEuroTrade; Axminster get a good press but are a little more expensive; that includes an extended warranty. As far as I know none of the UK Distributors are cowboys though some have been reported to be less sympathetic than others if there's a problem.
I recommend reading Neil's current series on lathes in Model Engineering Workshop. (Also Jason's parallel series on Milling Machines.) There's also a lathe series running in Model Engineer. I feel the ME series is Myford centric and for that reason a little old-fashioned. Neil is much more up-to-date and writes about an interesting modern lathe that you can buy new today.
Compared with a Myford Super 7, the Warco 250 is about the same size and capability. A 280 is like a 250 but bigger; it's about as big as I can fit in a cluttered single-garage sized workshop. No problem running it off a standard 13A plug. Next size up takes you into gear-head lathes which come with more time saving conveniences, but you have to start looking even more carefully at weight and power requirements.
What's wrong with Myford? Nothing much, a very successful and well-proven design. Unfortunately for both good and bad reasons they attract premium prices. For less money you can get even better quality kit like a second-hand Boxford or a new machine with warranty.
Hope that helps. I don't think you would go far wrong with a WM250 or an SC4. One last thing; buying a lathe used to be a once in a lifetime experience because they were expensive compared with income. That's not really true of hobby lathes today – many could realistically consider buying a £2000 lathe and replacing it after a few years. More expensive than a washing machine but cheaper than a car and definitely not an heirloom!
