Probably £1,000 to £2,000 range should turn up something private / E-bay depending on your luck and exactly what condition will do. Rather more from a dealer. Need to factor moving expenses too. Colchester Triumph 2000 is the common one to easily take over 1.5″ in the bore. Big lump for the home shop and, being well known, usually a bit pricey relative to condition. Master 2500 is 1 17/32 bore, which maybe just enough, and seems to go relatively cheaply on flea-bay. Elliot Omnispeed seems to be a good buy at the moment, if I recall correctly the spindle bore is bigger than on the older, Cardiff, equivalents.
