Which lathe you choose is governed by a variety of factors, particular to the individual concerned.
(Not necessarily in this order of importance to every purchaser )
1 What is it going to used to make?
2 How much space is available?
3 The budget
4 "Must have" features, as opposed to "Nice to have"
5 Not to mention transporting from delivery point to final installation.
(Moving a 300Kg machine, some distance over soft, possibly sloping, ground, and installing it, can be quite an undertaking.)
My already at least secondhand Myford ML7 eventually went because of the frustration with the small bore of the 2MT Headstock.
Its larger new Chinese successor had features that the Myford ML7 lacked. ( Larger bore Headstock, VFD, PCF., Power feed shaft separate from the Leadscrew,.
I had been going to buy the latest Myford Super 7 Sigma, but for the same specification ( Chucks, Steadies, Norton gearbox etc) it would cost at least four times as much as the eventual purchase, and could not have PCF which I was keen to have.
Effectively, although dual dialled, it was a Metric machine;, but is capable of cutting a greater variety of Imperial threads than Metric!
HTH
