Hi David
Ihave dealt with Warco and Chester, but both my mill and lathe are from Chester, mainly because there are not too far away should i have any problems. Both firms have given me good service over the years, and both offer similar products. I think Chester machines are a bit less expensive, but there tooling is more expensive,so roundabouts,and swings realy! As others will no doubt advise, go for the largest that space and price will allow, but remember that once you have the machines you will also need tooling,wich in the case of the mill could allmost double the cost of the machine itself. If you can manage to get to Harrogate in early May, then you will be able to see all the traders in one place and make a more informed choice. If i was about to spend a fair bit of cash i would realy make the effort to get there,and talk to as many folk as you can to avoid being dissatisfied with what you end up buying Good hunting
Cheers Derek
