I just read the details of the air needed from a similar dedicated plasma cutting machine. This one for instance which is a 30amp unit. The one I looked at was 25amps max. There isn't much difference.
It's turned out to be an expensive add on (for my wife) for what I want which was just tig and stick. Being fair about that though buying Xmas presents for me is always a problem and if needed I'm pretty sure I can boost it up by fitting something like a Clarke 2hp twin cylinder pump head. These go on Clarke's industrial blue range.
As some one mentioned in the 3in1 thread it's duty cycle isn't terribly good but I will probably set it up with the regulator on the compressor set at 5 or 6 bar and the one on the unit at circa 50psi. The compressor cuts back in at 8 bar. Might be ok. Depends on how long the torch needs to be on.
It's a hell of a spec for this type of compressor – this one is similar
I spent some time on that site looking to see what could be expected from different sizes of compressor. There are various versions of the one I bought though and numbers differ. Einhill do give a number which is unusual so decided to give it a go,
Use – I might do an engine Jason style some day and being able to profile plate would be useful. Also other things. The idea of clean cut is immediately suitable for welding. The deeper figure they give isn't. It seems that the way to use them is to move the torch at a rate that causes narrow angle sparks to come out of the back. Too slow and the angle will widen. Add the torch needing to be about 1mm from the work I wonder why they don't all come with a guide to space the torch off the work. I'm thinking about something based on a pipe clip. Simple as making anything at the moment is a bit difficult.
Edited By Ajohnw on 04/01/2017 19:40:03
