Posted by Ajohnw on 03/01/2017 20:18:15:
That;s what struck me about 3hp bodge, A lot used to reckon that a 3hp lathe motor couldn't be run on a 3 pin plug. I did have one. Some one had fitted a 3hp to it so that he could turn certain tool steels. It was a Viceroy. I'd guess that the belt drive just wouldn't transmit that much really. It didn't blow fuses though even though the full load current draw is usually about 13 amps so start up could be a lot higher.
I do wonder if one of 2 pole or 4 pole is more efficient or a different starting torque characteristic etc. I suspect it's just min cost. Many have a large pulley on the pump. Why not make it smaller as it would be cheaper. Leaving it the same size and increasing the other would cost more. The size of the big pulley might be needed to give the power transmission that's needed.
Going from memory on m/c i have the motor pulleys is about 4 inch dia, & the driven pulley a good 12 inch dia , the spokes on the big pulley are fan blade shaped to get a bit of air blast over the cylinders so 2800 rpm is going to be better than 1400 rpm in that respect.
though of course the big pulley is not doing 2800 rpm
It looks like just your average compressor as sold by Clarkes / machine mart , though i bought it from a company that went by the name SIP years ago, ..3 hp = about 2.2 KW there are quite a few house hold appliances that draw that these days so i dont really see any problem with using a 3HP motor . Clarks and co must of sold hundreds of them over the years!
Have seen some real old compressors that where really slow running , but with compressors its all about how much free air cubic feet per minute , which with a 3 HP motor is usually around 14 CFM
i agree that a 2 pole motor is going to be cheaper to make than a 4 or 6 pole motor but i still got a nagging idea it may be a bit more efficient but i dont know enough about electric motors to be sure about that ,…not much help really , well got to go put the kettle on that draws 2 Kw, thirsty work typing…………b
Edited By bodge on 03/01/2017 22:01:37
