Further to my earlier post, my new Chester D13R bench drill arrived yesterday, as promised. It was snowing at the time! However the driver was very helpful and managed to get the large, palleted, box across about 30 yards of gravel drive and then helped me lift it into my shed. It seemed well packed, but one small screw for adjusting the belt tension had its plastic 'thumb screw' broken. I've been promised a replacement.
I was disappointed to find the chuck was keyless. However I've checked the website and there's no mention of key or keyless. So don't make assumptions – my fault entirely.
The worm gear for raising and lowering the table needed a few minutes work with a file to make it work freely. Otherwise the only possible comments on the condition were that a small amount of paint had to be removed from the lower fixing for the table rack and the plastic cover over the on/off switches was wrongly fitted – trivial and easily corrected. The motor runs smoothly and quietly. One thing that I particularly looked for was play at the drill point with the quill fully extended. I estimate this to be a couple of thou only – pretty good. The instruction book is generic and doesn't claim to cover my model, but everything is very straightforward.
So, excellent service from Chester, before and after purchase, with the machine delivered in good order. However the procedure for changing speed seems to be a real pain. Firstly the belt cover is held closed by a fiddly little cross head screw. I've added a rubber buffer for the cover to rest on and will rely on gravity to keep it shut. Secondly the belt tension is adjusted by moving the motor in or out on two horizontal pegs locating in lugs on the drill head and locked by two thumb screws – see above. There is no built-in means of moving the motor and I found I had to put a lever between it and the head and heave. Quite a struggle to shift it. According to the instruction book, larger models have lever adjustment.
Moral: make sure you ask the right questions before buying and/or have a look at the product first – not so easy from remote Norfolk. Never the less I'm very pleased with my first ever piece of brand new equipment and hope speed changing gets easier with practice.
Bill.
