Which books
Which books
Home Forums Books Which books
Viewing 25 posts - 1 through 25 (of 44 total)
  • #366617
    Dalboy
      @dalboy
      Not yet having any machines except my woodworking ones, I thought I would start by just having a read up on working with metals and the different techniques.
      Which books are at the top of your list for a beginner to collect and read. As well as books that will always be useful. This includes reference books.
      I already have Model Engineering a Foundation Course" by Peter Wright as well as a Zeus booklet which I used a lot in the plant mechanics roll.
      Dalboy
        @dalboy
        #366620
        Brian G
          @briang
          I have two copies of Tubal Cain's "Model Engineers Handbook", one by my desk, one in the workshop, so I guess it would be my first recommendation
          #366621
            Peter Wright's book was my starting point.
            Many classic books on lathework are very good but obviously leave out a huge amount relevant to modern practice.
            Naturally, though, I'd suggest a subscription to Model Engineers' Workshop
            Edited By Neil Wyatt on 10/08/2018 12:37:51
            #366632
              Neil is too modest to recommend his own 'The Mini-lathe' so I will. I'd also recommend 'The Amateur's Lathe' by Sparey.
              For reference, Tubal Cain's 'Model Engineer's Handbook' is succinct. Machinery's Handbook covers much more!
              Although the books above answer many questions, they also open the door to many more. Much depends on where your interests take you – Sheet Metal, Castings, Clocks, Welding… Fortunately there are plenty of good books available.
              Not all are equally on target, but I find the Workshop Practice Series good for specific subjects.
              Also have a look at the Camden Website – they stock a very wide range of engineering related books. Most are in the Engineering Practice and Skills section, but Technical Steam, Horology, Electrical, Foundry, Hot Air Engines and other sections also have gems.
              Thor 🇳🇴
                @thor
                Hi Derek,
                Have a look at some of the books in the Workshop Practice series, they should cover the most for now. If you don't want to buy the ones you are interested in, may be your local library can help.
                Thor
                #366642
                Howard Lewis
                  @howardlewis46836
                  + 1 for Tubal Cain's book.
                  Although written when the Myford ML7 was the most populous lathe, Sparey's "The Amateur's Lathe" is a good starting point, followed by Bradley's "The Amateur's Workshop". "The Myford Series 7 Manual" is specific, but contains information that is useful elsewhere. After that you are into books from the "Workshop Practice Series", for more specific activities, such as Soldering and Brazing, Taps and Dies, Workshop Hints and Tips, Making Small Workshop Tools, Screwcuttiing in the Lathe, and when you are more experienced and confident; Milling, or Gearcutting.
                  The books by Neil Wyatt and Dave Fenner deal with the mini lathe, but the techniques and principles, if not the specifics, can be read across onto other machines.
                  If you want to get into screwcutting, Brian Wood's "Gearing of Lathes for Screwcutting" can be a good source of information, so that you grasp the principles involved.
                  Plus, you will always have a crowd of folk on here who will be happy to give advice, and even practical help.
                  #366645
                  Mick B1
                    @mickb1
                    Chapman's 'Workshop Technology' has been with me for 43 years, and seems to me to provide a complete basis – although some modern techniques are of course absent.
                    #366650
                    Lambton
                      @lambton
                      The first book I bought (many years ago now) and found very useful was Using The Small Lathe by L C Mason. It takes the new lathe owner through all the turning methods likely to be needed. Very readable and superbly informative.
                      Also +1 for 'The Amateur's Lathe' by L h Sparey especially f you intend buying a Myford lathe.
                      .As you gain experience try The Model Engineer's Workshop Manual by G H Thomas.
                      Good luck
                      Eric
                      #366660
                      Carl Wilson 4
                        @carlwilson4
                        LH Sparey’s book is very good. Most of what he talks about in the book is done on Drummonds, so seems like a good book for the smaller lathe.
                        Lathework, a Complete Course, by Harold Hall is also very good. It’s a Workshop Practice series title. I too have Chapman, from over 30 years ago in training and still excellent.
                        I’m going to suggest something else that is not a book. Machining is inherently practical. Watch some of the you tube machining channels.
                        In my opinion the best one is a guy called Doubleboost. He is British and he is very down to earth and does some interesting projects. His channel is Sunday Night Night Cap. Puts out a new video every Sunday. The old ones are all archived. Highly recommend – equal worth to reading several books.
                        #366667
                        Dalboy
                          @dalboy
                          Thank you all Tubal Cain's book seems to be the fist one to get as well as the workshop series books as needed. Still got plenty to read in the one I have so will order some soon so as to have one ready for when I finish this one.
                          #366697
                          larry phelan 1
                            @larryphelan1
                            L.C Mason and Sparey and you can,t go too far wrong. If you can get through both of those,you,re well on the way !
                            Be warned , This is infectious !!! There is no known cure for it.
                            #366718
                            richardandtracy
                              @richardandtracy
                              To gain an appreciation of what can be done at home with very little, I'd recommend the David Gingery series 'Build your own Metalworking Shop from Scrap' here: **LINK**
                              You don't need to make any of the machines, just learn the thought processes and get a feel for it all. It's a complete industrial revolution in one bound volume.
                              Richard.
                              #366878
                              merlin
                                @merlin98989
                                Derek Lane 2, I am never going to extract any more from my 1948 edition of Sparey's The Amateur's Lathe so I will give it to you if you pay the postage.
                                I live in North Norfolk – is this anywhere near you?
                                How do we do this i.e. please explain how you and I exchange details privately.
                                #366890
                                  Posted by merlin on 11/08/2018 23:10:19:
                                  One of you needs to start by sending a personal message to the other
                                  [assuming that you are logged-in] You will see a 'Message member' link at the bottom-left of any previous post.
                                  robjon44
                                    @robjon44
                                    Hi all, +1 for Chapmans Workshop Technology, pretty comprehensive in every way, only yesterday I was wrestling with a problem that someone had asked for help with, 10 minutes with the textbook provided the precise answer, slam dunk!
                                    Bob H.
                                    #366912
                                    Ady1
                                      @ady1
                                      +1
                                      Was the bible for me starting out
                                      #366932
                                      Bob Stevenson
                                        @bobstevenson13909
                                        Yes, 'Sparey' is a great book which is quite inexpensive now and has helped legions of lathe users over many years…….
                                        Someone could do the machining world a great favour and re-edit 'Sparey' by taking out the chapter on fitting a treadle and replacing it with another on Chinese lathes and QCTP's along with some modern electric motor info and good old 'Sparey' would be good to go for another several generations……
                                        #366989
                                        Nick Clarke 3
                                          @nickclarke3
                                          Returning to model engineering after a gap of nearly 45 years has really brought home to me the need fir an up to date readable book on modern techniques. Reading through the posts I suspect I am not alone in this.
                                          Topics that I think need to be in an updated book, even since I modelled in the 1970s, could include:
                                          Metrification, DROs, 3D printing, tig and mig welding, the ready availability of machines, not so Myford focussed as in the past, invertors, no blowlamps or air/towngas, disappearance of one-off foundries, new materials like plastics, laser cutting and changes to boiler codes and soldering materials.
                                          And I have no doubt many more could be added!
                                          Apart from books about model engineering, Tubal Cain’s reference book is essential as a source of information, but I have to admit it is not really a bedtime read!
                                          Edited By Nick Clarke 3 on 12/08/2018 21:29:30
                                          #366992
                                          Anonymous
                                            Posted by Nick Clarke 3 on 12/08/2018 21:20:34:
                                            Wot? No CNC? Must be a step too far! smile
                                            #366995
                                            Nick Clarke 3
                                              @nickclarke3
                                              Posted by Andrew Johnston on 12/08/2018 21:43:21:
                                              I quite agree Andrew – originally I included it but lost my post through operator error before I uploaded it and missed it when reposting.
                                              Incidentally I used to work with a teacher of technical drawing who claimed to teach from resources in a filing cabinet, none newer than 25 years old. At least with CNC & CAD that is unlikely to happen!
                                              Edited By Nick Clarke 3 on 12/08/2018 22:01:22
                                              #366999
                                              richardandtracy
                                                @richardandtracy
                                                Think that at the moment home CNC is in a pretty immature state compared to other branches of the hobby, and is changing rapidly enough to date very quickly. Think of the advent in the last couple of years of the little self contained controllers, the Arduino and the PlanetCNC type controllers all changing so rapidly that a book would become out of date while being written. The same applies to 3D printing, only more so.
                                                Richard.
                                                #367000
                                                Nick Clarke 3
                                                  @nickclarke3
                                                  Dunno about 3d printing as I only have experience of my own machine, but I was teaching CNC in school in g code using a small CNC lathe attached to a BBC computer in the late 1980s
                                                  #367024
                                                  Dalboy
                                                    @dalboy
                                                    #Posted by merlin on 11/08/2018 23:10:19:
                                                    Again thank you every one have been a little busy over the weekend with preparing for an event on saturday and out at it all day yesterday totally shattered.
                                                    Merlin thank you very much and I have sent a PM to you. I am down in Canterbury.
                                                    I will be looking at the Tubal Cain's book as well as the workshop series as I stated earlier
                                                    Edited By Derek Lane 2 on 13/08/2018 08:39:39
                                                    #367049
                                                    thaiguzzi
                                                      @thaiguzzi
                                                      Posted by Carl Wilson 4 on 10/08/2018 16:43:10:
                                                      LH Sparey's book is very good. Most of what he talks about in the book is done on Drummonds, so seems like a good book for the smaller lathe.
                                                      Lathework, a Complete Course, by Harold Hall is also very good. It's a Workshop Practice series title. I too have Chapman, from over 30 years ago in training and still excellent.
                                                      I'm going to suggest something else that is not a book. Machining is inherently practical. Watch some of the you tube machining channels.
                                                      +1, concur.
                                                      But i would add the two American channels Abom79 and Keith Fenner's Turnwright machining. Both always very interesting.
                                                    Home Forums Books Topics
